Valve Cover Gasket
Old Oct 19, 2007 | 10:59 AM
squire's Avatar
Default Valve Cover Gasket
I'm changing the valve cover gasket on my 96 accord and I was wondering if I need to use some kind of sealant or if the gasket alone will be sufficient. Thanks
Old Oct 19, 2007 | 11:06 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Valve Cover Gasket (squire)
put some Hondabond in the corners where the gasket goes over the cam journals.
remember, 7lbs/ft for the valve cover bolts, they snap easy.
Old Oct 19, 2007 | 11:24 AM
TypeRSR's Avatar
* B A N N E D *
get a new one
Old Oct 21, 2007 | 08:15 PM
aasaa666's Avatar
you should get honda genuine VC gasket, tube seals, and grommets. They last longer! the quality of the material is better than aftermarket much like Toyota genuine parts. I bought a set from checkers and in 3 months it leaked.
Old Oct 22, 2007 | 04:19 AM
H-T Order of Merit
Default Re: Valve Cover Gasket (TypeRSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRSR &raquo;</TD></TR><TR><TD CLASS="quote">get a new one</TD></TR></TABLE>
they said they are changing the gasket, therefor I would assume that means new. Why would someone change to a used one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aasaa666 &raquo;</TD></TR><TR><TD CLASS="quote">you should get honda genuine VC gasket, tube seals, and grommets. They last longer! the quality of the material is better than aftermarket much like Toyota genuine parts. I bought a set from checkers and in 3 months it leaked. </TD></TR></TABLE>
where did the OP say what brand they were buying? For all we know they are buying OEM. Besides, that wasn't the question, they were just wondering if they needed liquid gasket or if the gasket alone was enough to seal the valve cover.
Old Oct 23, 2007 | 11:45 PM
aasaa666's Avatar
yeah i know. I didnt misread it. just making a recommendation. That way if someone was reading this and happen to do their own, they wont have to search couple hundred threads to find all the info they need. no harm in that right? just happy to say that my VC gaskets havent leaked for 2 years+ ever since I used the factory ones.
Old Oct 24, 2007 | 03:43 AM
H-T Order of Merit
Default Re: Valve Cover Gasket (aasaa666)
agreed
Old Mar 9, 2008 | 10:42 PM
tomatocity's Avatar
Default Re: Valve Cover Gasket (TouringAccord)
aa...I appreciate your input. And I think it is allowed
Old Mar 10, 2008 | 03:40 AM
H-T Order of Merit
Default Re: Valve Cover Gasket (tomatocity)
huh???
CeeJayy
Feb 27, 2007 07:28 PM
-Championship-
Jun 29, 2006 10:59 PM
4DRmafia
10
Jun 29, 2004 08:35 PM
LilGreenMachine
Jun 12, 2004 01:58 PM
hb_racer
Aug 4, 2002 11:58 AM
