Built For Turbo - LS Longblock - Eagle, STR, Cometic, ACL, ARP
Old Oct 19, 2007 | 10:39 AM
Honda_Fanatic's Avatar
Default Built For Turbo - LS Longblock - Eagle, STR, Cometic, ACL, ARP
*******************PENDING SALE*******************
The build was done less than 5k miles ago and everything was purchase new except DSM 450's. Never been boosted yet, this setup could easily handle 20psi 350hp turbo kit. And should last a long long time. The only reason I am selling is because I decided to go another route and go ALL moror GSR instead.
$1500 obo. For another $500obo I will include the LS tranny (rebuilt w/ new syncros about 20k ago) w/ ACT 9.5lb Flywheel and Stage 1 Excedy Clutch.
This is the list of parts used for the build. It is running great (burns no oil etc..150psi accross) Any questions PM me - My name is Derek. Thanks
Probe Industries Forged turbo pistons 9:1 81mm
Eagle H-beam rods ARP 2000 3/8
ACL main bearings
ACL rod bearings
ACL thrust washer
ARP Rod Bolts
ARP Main Studs
ARP Head bolts
Micropolished knife-edged crank at 29lbs
STR block guard
Goodyear Gatorback timing belt
OEM tensioner from omalleys(honda)
OEM valvetrain from omalleys(honda)
OEM waterpump from omalleys(honda)
OEM ls camshafts from omalleys(honda)
OEM rockers from omalleys(honda)
OEM valve cover gasket, gromets, tube seals from omalleys(honda)
New thermostat
Cometic head gasket
Felpro oil pan gasket
Vision cam seal
NGK spark plugs
Overbored throttle body 66mm
Exedy stage 1 clutch w/ pressure plate
9.5lb ACT flywheel
Fresh Hone
Ready for the tubo kit of your choice!
Modified by Honda_Fanatic at 6:22 PM 10/20/2007
Modified by Honda_Fanatic at 12:42 AM 10/27/2007
Old Oct 19, 2007 | 11:26 AM
touchmyHONDA's Avatar
wow sick
Old Oct 19, 2007 | 11:27 AM
snowseeker's Avatar
Default Re: Built For Turbo - LS Longblock - Eagle, STR, Cometic, ACL, ARP (Honda_Fanatic)
Price?
Old Oct 19, 2007 | 01:02 PM
Default Re: Built For Turbo - LS Longblock - Eagle, STR, Cometic, ACL, ARP (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Price?</TD></TR></TABLE>
1500obo.
Old Oct 19, 2007 | 05:01 PM
B.J.'s Avatar
bump
Old Oct 19, 2007 | 08:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.J. &raquo;</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
Thanks
Old Oct 20, 2007 | 02:57 PM
bump - tregsdgfd
Old Oct 21, 2007 | 06:16 AM
HonDA Integra XSI's Avatar
bump
Old Oct 21, 2007 | 02:23 PM
thanks
Old Nov 3, 2007 | 10:32 PM
Ryan97's Avatar
obd0 im guessing?
Old Nov 4, 2007 | 04:42 AM
Default Re: Built For Turbo - LS Longblock - Eagle, STR, Cometic, ACL, ARP (Ryan97)
obd1
Old Nov 4, 2007 | 07:36 AM
Ryan97's Avatar
Very interested
Old Nov 4, 2007 | 01:03 PM
Read first post!
Sale already pending. (If payment doesn't clear I will let you know!)
Old Nov 28, 2007 | 08:12 PM
byrne_06's Avatar
pm'ed
Z0831xiz
Engine Machining & Assembly
Aug 29, 2016 08:31 PM
got dell
Nov 3, 2009 08:04 AM
Honda_Fanatic
Nov 9, 2007 02:18 PM
Honda_Fanatic
Oct 26, 2007 07:01 PM
Honda_Fanatic
Oct 25, 2007 08:23 PM
