Keyless Entry Question (Alarm activated, keyless died)
Well, my car is currently up at my University because the alarm is activated and my keyless died. I bought this keyless remote two years ago and it already died, I'm a bit irritated as the one before it died too. I noticed my old one's red light still glows when I push the buttons, which is odd, but I think it wasn't sending a signal.
Back on topic, I was going to buy a new one today, but I think I read that you can only have four keyless remotes for a car. I know this will be my third, and since I'm not the original owner I'm unsure if there were more purchased before that Is there any truth to this? If there is, what do I do?
I wouldn't mind disconnecting the alarm and just open the door by hand, but have no idea on how to go about disconnecting an alarm (and I fear I sound like a thief asking anybody). Please help! I'm stranded without my car.
This is on a 1999 Civic EX, by the way.
EDIT: I guess I wasn't clear enough, I already replaced the battery.
Modified by KHowe at 7:38 PM 10/19/2007
replace the batteries? if not I would ask the installer how to detach the alarm, then i would get in the car and detach the alarm. Upgrades are always a good thing!
Oh yea what if you sound like someone that is trying to steal it, remember it is your car! Even the cops can't say **** about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morning Call »</TD></TR><TR><TD CLASS="quote">im kind of curious why you dont replace the batteries?</TD></TR></TABLE>
I replaced the battery yesterday, it was the first thing I did, still didn't work. Like I said, the keyless remote is dead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillthingz »</TD></TR><TR><TD CLASS="quote">replace the batteries? if not I would ask the installer how to detach the alarm, then i would get in the car and detach the alarm. Upgrades are always a good thing!
Oh yea what if you sound like someone that is trying to steal it, remember it is your car! Even the cops can't say **** about it.</TD></TR></TABLE>
Well, it's the factory alarm, not aftermarket, so I thought someone here might know.
The remote needs to be reprogrammed to the radio.
96-98
Programming the Transmitter
1. Turn the ignition switch to ON (II).
2. Press and hold the Valet-Disarm button on the radio (between the AM/FM and CD/TAPE buttons) to enter the programming mode. (Continue to hold the button during this procedure, or programming will be cancelled.) Check that the power door locks cycle to confirm that you’re in the programming mode.
3. Within 5 seconds, press the “Lock” or “Unlock” button on the transmitter. Check that the power door locks cycle to confirm that the code was accepted.
4. Within 10 seconds, press the “Lock” or “Unlock” button on each of the remaining transmitters.
5. After all the transmitters have been programmed, release the Valet-Disarm button to exit programming mode.
99-05
2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
96-98
99-05
Just got back from Honda dealership, they said they can't program a new keyless remote without my car being there, and I obviously can't drive it.
He said there is a button to deactivate the alarm between the AM/FM button and the CD Player button. I just pulled up images on google of the CD Player, and I see no such button. Is it perhaps the two radio tuning buttons?
He said there might be a black button underneat the dash that I can hit. Does any of this sound familiar to anyone?
There was no black button on my radio between the AM/FM and CD player button. Perhaps on the 96-98 there is, but not on my '99. Hmm.
What's the silver button do on the left side near the pull out ash tray?
KHowe
Audio / Security / Video
Oct 19, 2007 04:47 PM
GSRpower
Nov 1, 2002 04:38 PM
drsues02
May 17, 2002 10:06 PM
