Suspension & Brakes Theory, alignment, spring rates....
5 lug conversion
Old Oct 19, 2007 | 09:21 AM
Myslowdc4's Avatar
Default 5 lug conversion
Do you know what axles can I use for the JDM ITR 36mm hub cause Autozone sells the usdm axles which is 32mm and not the JDM Type r. Please I need to know.
Can I swap the USDM ITR hub which is 32mm to a JDM ITR suspension that comes with a 36mm, would it fit with no problems.
Old Oct 19, 2007 | 10:48 AM
SilverDc2's Avatar
Default Re: 5 lug conversion (Myslowdc4)
yea need to go to a place where they make axles and tell them to put the prelude/accord 36mm end instead of the 32mm on a regular integra axle.
that what a buddy of mine did.
you COULD change the hub but that would be costly.
Old Oct 20, 2007 | 01:46 AM
BlueIntegraBoy's Avatar
Default Re: 5 lug conversion (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">you COULD change the hub but that would be costly.</TD></TR></TABLE>
Which pretty much defeats the purpose of buying a 5-lug. You could have bought regular Integra knuckles and have the USDM ITR hub pressed in and buy ITR calipers. I would go with the axles deal, much cheaper.
Old Oct 21, 2007 | 07:53 AM
Myslowdc4's Avatar
Another question if a have a JDM type R with a 36mm hub and the wheel bearing got f up what wheel bearing can I use that will fit with the 36mm hub ?
Old Oct 21, 2007 | 11:33 AM
I believe a 97-01 CRV wheel bearing will work
FRKWOO
Jan 15, 2011 06:47 PM
Boriqua0555
Jun 28, 2007 10:13 AM
B18C Turbo
Feb 18, 2007 09:03 AM
cashkid2004
Oct 1, 2006 06:41 AM
Garrett
Jun 7, 2004 06:49 AM
