Type R side skirts?
no such things, the only difference between type-r sides to non type-r sides, is the type-r's came painted to match the car
the sides you're more than likely thinking about
are the oem optional sideskirts
which if you really want OEM ones, are usually a bitch to find, and are pretty exspensive, there are a few places that make knock off fiberglass versions that you'll more than likely find alot easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KBG Indey »</TD></TR><TR><TD CLASS="quote">no such things, the only difference between type-r sides to non type-r sides, is the type-r's came painted to match the car
which if you really want OEM ones, are usually a bitch to find, and are pretty exspensive, there are a few places that make knock off fiberglass versions that you'll more than likely find alot easier</TD></TR></TABLE>
The OEM ones are hard to find. Replicas would be your best bet. I found a pair on ebay for $130. Im about to install this weekend so we'll see how they come out. good luck on your search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsmdc4teg »</TD></TR><TR><TD CLASS="quote">The one thing to watch out with the replicas is there lack of perfect fitment cmpared to oem. Ive heard of most people having to trim them to get them to fit as close to oem as possible</TD></TR></TABLE>
there were ebay side skirts on my s13 when i got it and they fit worse than anything. also consider that fiberglass will crack and break easily and the factory urethane ones wont. its def better to spend extra and go w/ factory or better quality ones
