power goes out when shifting
Old Oct 19, 2007 | 08:31 AM
equinox's Avatar
Default power goes out when shifting
I have a 97 honda prelude AT w/ 103,000.
When the transmission shifts gears all the power would go out from the car. By that, I mean the radio turns off, all the gauges go back to zero, and I would feel the car have no power. This occurs for about a full second in between gears and then everything would turn on again when i'm in the next gear.
This just started happening yesterday and my ABS light is now on. Where should I start looking for problem sources?
p.s. battery connections are fine and it's a new battery.
Old Oct 19, 2007 | 08:35 AM
98vtec's Avatar
moderator emeritus
Default Re: power goes out when shifting (equinox)
check for loose grounds
check your alternator
Old Oct 19, 2007 | 09:46 AM
cb7tougeracer's Avatar
Default Re: power goes out when shifting (98vtec)
i 2nd the alternator
Old Oct 19, 2007 | 08:52 PM
mattsnooz's Avatar
Default Re: power goes out when shifting (cb7tougeracer)
check for loose ground to your tranny from your negative at battery tray
Old Oct 21, 2007 | 09:49 AM
equinox's Avatar
alright i'll check those out. Thanks for the responses
Rarytas
Sep 18, 2012 07:44 AM
Cliche_EK
Feb 28, 2008 06:02 PM
bgcrx
10
Jun 2, 2007 09:03 PM
MzStreetracer
Mar 6, 2007 08:38 PM
jdmCivic925
Aug 22, 2004 05:53 PM
