96 Honda Accord EX-R Brakes
Old Oct 19, 2007 | 07:04 AM
dueceman's Avatar
Default 96 Honda Accord EX-R Brakes
this is a similar question to one posted for a 93 ive never had an accord before so i dont know if this is a characteristic of accords or if its just that the pads on my car are quite worn but there is quite a bit of pedal travel in the brake before the pads actually contact the rotor..
its been tough to get used to as i had an 88 325is and you good break with the left side of your right foot simply by rolling your foot as the pedals were matched up..
any comments are appreciated.. maybe a new master cylinder?
or better pads?
thanks..
Old Oct 19, 2007 | 09:45 AM
Hatepylons's Avatar
Default Re: 96 Honda Accord EX-R Brakes (dueceman)
Have you had an opportunity to see what the pad thickness is on your car now? On my 97 the brake pedal, when fully engaged, does dip slightly below the gas pedal, but even moreso as the pads wear.
Also, another culprit could be sticking rear calipers - if the E-brake isn't acutated often the caliper piston won't rotate out and sit tightly against the inboard pad, leading to excessive pedal travel.
kevinhughes13
Jul 21, 2014 07:15 AM
lazychina
May 18, 2011 04:17 PM
Outlaw-Hondaz
Dec 10, 2010 07:18 PM
SiR Inspired ED7
Suspension & Brakes
Feb 24, 2010 03:31 PM
CivicSD
Apr 22, 2008 10:08 AM
