Can you tell if this is an OBDI or OBDII b18? *pics*
I was thought it's OBDII (1997 engine). Now I'm wondering. Is there anyway to tell from these pics?
https://honda-tech.com/zerothread/2123980
do you know for sure if that is the stock ecu that came with the motor? as long as it's not a different LS ecu the exact date it left the factory should still be stamped on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">Where is the date stamped?</TD></TR></TABLE>
it should be stamped on the side with what looks like someone literally had a black ink stamp with the date on it.
I.E. my p28 says Mar. 23 1995 since it was out of my friends 95 civic EX whereas my p06 from my 4 door says Dec. 11 1991 on it.
Bro those pics aint doing me justice lol but from what i see i'ved worked on my homies ob2 and it looks like that but need better pics and i could tell you exactly what it is i no b18s good i was a former b20 b16 head then moved to a ls v-tec and worked on b18's allot at school so i see that its a ob2 but take better pics and i'll tell you fo sure peace .
<FONT COLOR="red">Theres a black breather box on the back of the block - Block itself is obd1 (period)</FONT>
Intake manifold is obd2 because of the port on top for the evap
p75 came in obd1 and obd2
<FONT COLOR="red">As far as the head, read the year stamp above the 3rd runner -> (9|x)</FONT>
You canNOT look at things like the valvecover, dizzy, alternator, etc since those things are easily swapped around.
Modified by pdiggitydogg at 11:15 AM 10/19/2007
the engine is going to run how the ecu tells it to
thats really all that matters unless youre getting the car smogged
other than 2ndary o2 and some other minor things, obd1 and obd2 p75 ecus are exactly the same anywys...just like the engines themselves
Only way to tell is looking at the head stamps. Seriously (like pdiggity said) everything that can be attached to a motor can be either obd0, obd1, obd2A, obd2B. That does not mean **** when it comes to the motor itself. Motor itself is marked by the head, the block is really hard to tell except for different sensors.
the dizzy is obd2 and the ecu is a obd2 as for the block and head, on the head there is a stamp upper left side there is a square that will say p75-? is it is a dash 1 than its a obd1 if it says dash 2 than its a obd2. as for the block I dont know anyway of telling if it is obd1 or obd2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superls92 »</TD></TR><TR><TD CLASS="quote">it's obd1.</TD></TR></TABLE>
Because everything you have to go with it is obd1, the p75 ecu is obd1,obd1 intake manifold,obd1 distributor........ If you want a better answer you need to take better pics, take a pic of the front of the engine, the stamping on the head above where the header goes. Does the block have a green vin tag on it??
If thats the original valve cover then its OBD1 94-95. But P75 came in both OBDI and OBDII. Then your dizzy looks to be OBDII.
I dont know...
I dont know...
I'm sure that valve cover came on the b18a in the 90-93 integra, but it could easily be put on a b18b head. Maybe someone put a b18a1 head on a b18b.. Maybe he should take a pic of the plugs on the ecu, and the stamping on the head, and the stamping on the block.
