Fuel injector problems, need advice on diagnosing problem h22
Old Oct 18, 2007 | 05:39 PM
egCivicH22's Avatar
Default Fuel injector problems, need advice on diagnosing problem h22
Hey all,
I just finished my h22eg install. the cars running rough checked the normal stuff and found that the #4 plug is not carbed at all. so I disconnected the spark plug wire turned it over a few times and then pulled the plug again, and no fuel on it. So I figure its the injector not spraying. so far I've checked the resistance its good at 2.3 ohms, and tested the signal wire from the ecu and its not a constant value, but it is showing a fluctuation in dc volts. what should I be testing for? whats the next step. I do have the resistor box hooked up, but have not verified (again, that everything is hooked up properly) figured if the other 3 are working then its most likely the injector.
thanks in advance.
Old Oct 19, 2007 | 12:41 PM
egCivicH22's Avatar
Default Re: Fuel injector problems, need advice on diagnosing problem h22 (egCivicH22)
does this mean no advise, or I've done all that I can?
NevinJoe
Sep 17, 2025 12:50 PM
CARMA_626
Feb 13, 2013 11:26 AM
2muchboost2blow
Mar 25, 2006 09:22 AM
0 0 0
11
Apr 15, 2004 01:45 PM
