GIRL NEEDS HELP GETTING POWER TO ECU
Old Oct 18, 2007 | 04:31 PM
hannahscrx's Avatar
Default GIRL NEEDS HELP GETTING POWER TO ECU
hey awhile back I bought a crx off my brother and was running fine. One day it just didn't start up. i don't know a lot about cars, but he told me that there was no power going to the ecu. I've been searching and searching and I can't find any answers. how much would it cost to replace the ecu (if that's what it needs) and/or replace the power supply to it? argh. please help...I don't know where to start.
thanks
Old Oct 18, 2007 | 04:36 PM
tougetuned_ef's Avatar
Default Re: GIRL NEEDS HELP GETTING POWER TO ECU (hannahscrx)
get a shop manual and it will tell you how to test if the ecu is bad. it will also tell you what color the power wire is that go to the ecu in the back of the maual in the wiring diagrams.
Old Oct 18, 2007 | 05:00 PM
hannahscrx's Avatar
Default Re: (Dustin_Pierce)
i feel stupid but where would I look in the manual. under electrical?
Old Oct 18, 2007 | 05:06 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
When you turn on the key,
Does the "check engine" light come on,then go off after a few seconds?
If not check fuse #14 under the driver side dash..
Old Oct 18, 2007 | 05:16 PM
88DXCRX's Avatar
There are also fuses under the hood near the battery for the ecu:
Old Oct 18, 2007 | 08:25 PM
crx_si-r's Avatar
Default Re: (88DXCRX)
check to make sure the battery cables are making a good connection as well. and check all the grounds.
Old Oct 18, 2007 | 08:31 PM
Guiding my way back.'s Avatar
* B A N N E D *
Default Re: (crx_si-r)
engine grounds and tranny grounds are your friend fix them if they look like they have a shitty connection. if they have bad connections it can keep your car from starting!!!
95_red_dc
Jan 6, 2008 11:46 AM
KraziCivicSi
Dec 22, 2007 10:07 PM
MrMayhem
Nov 22, 2005 07:54 PM
mockujin
Nov 14, 2002 07:43 PM
KevronsEG
Apr 21, 2002 01:49 PM
