Suspension & Brakes Theory, alignment, spring rates....
eg to ek omnis
Old Oct 18, 2007 | 03:25 PM
95Sol's Avatar
Default eg to ek omnis
what would have to be done to make some full omni coilovers fit on an ek? and the stock ek suspension onto the eg?
i know the lca's are different....can you just swap them?
Old Oct 18, 2007 | 04:08 PM
slammed_93_hatch's Avatar
Default Re: eg to ek omnis (95Sol)
you either need 4 5mm spacers, or you need to grind off 5mm on each side of the LCA bushing were the shock goes.
I can't ever remember which why it goes.
But there is nothing wrong with adding the spacers or grinding down.
Old Oct 19, 2007 | 05:59 PM
95Sol's Avatar
that doesnt sound too bad.
u cant swap the lca's between the two though?
Old Oct 20, 2007 | 12:40 AM
Voyage34's Avatar
Default Re: (95Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95Sol &raquo;</TD></TR><TR><TD CLASS="quote">u cant swap the lca's between the two though?</TD></TR></TABLE>
no theyre differnt length and swapping them would expletive up your alignment quite horribly
Old Oct 20, 2007 | 03:57 AM
95Sol's Avatar
ok
and the front just drops into place
95delslo
Suspension & Brakes
Mar 4, 2007 03:31 PM
oldskoolaccord
Jan 18, 2007 03:11 PM
turbochargeb18c
Suspension & Brakes
Jul 6, 2006 07:01 AM
TurboGabe
Suspension & Brakes
Apr 11, 2006 08:15 AM
G.R.eg
Oct 17, 2005 03:51 PM
