EM1 Clutch
Old Oct 18, 2007 | 11:27 AM
mtownek9's Avatar
Default EM1 Clutch
The clutch on my EM1 is starting to act funny, I can barely chirp first anymore. It is the stock clutch with 100,000 miles. Does it need replaced? If so, Can I just buy a new disc or do I need to buy a whole kit with everything?
Old Oct 18, 2007 | 12:20 PM
DOHC4banger's Avatar
Default Re: EM1 Clutch (mtownek9)
mine is startin to do the same thing...
Old Oct 18, 2007 | 12:31 PM
SimplyTron's Avatar
Mine is doing the same thing. Slips when shifting and at the track, forget it more traction = more slip. What you need depends what you are going to be doing with it. It you just drive it and its going to stay stock you can get a new OEM clutch disc and pressure plate. Check your flywheel to see if it needs resurfaced. For a little bit more check out Exedy Stage 1 clutch and pressure plate. I have ahd really good luck with those. But just don't forget about the flywheel, if its too grooved up just get a new one.
NeverEnding_Ej8
14
Jan 5, 2014 04:13 PM
iwanttogofast
Feb 26, 2007 07:34 PM
Integra_drk
Jan 18, 2006 08:23 PM
danny98r
Jun 24, 2004 12:15 PM
DsITR
Dec 9, 2002 01:00 PM
