Blown Fuse - 95 Civic
Old Oct 18, 2007 | 11:17 AM
knick08's Avatar
Default Blown Fuse - 95 Civic
When I replaced my antenna, I tripped the fuse that runs the instrument lights and taillights. I assume I did something to the wires along the path of the antenna wire. The fuse will blow whenever replaced but I cannot find the wiring issue in the cluster under the dashboard. Any suggestions on how to troubleshoot this issue?
Old Oct 18, 2007 | 11:29 AM
OversteerMotorSports's Avatar
Default Re: Blown Fuse - 95 Civic (knick08)
I seem to always trip that fuse when hooking up a stereo in a car. Just trace your tracks and look for any wires arching out. Be sure there are absolutely no bare wires.
Bump for more answers.
Old Oct 18, 2007 | 11:43 AM
fmrprojects's Avatar
Default Re: Blown Fuse - 95 Civic (OversteerMotorSports)
you have a short to ground somewhere. just go through and trace where you worked and see if you have any broken wires touching ground
knick08's Avatar
Any particular wires I should be checking?
Old Oct 18, 2007 | 11:48 AM
any power wire or signal wire
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knick08 &raquo;</TD></TR><TR><TD CLASS="quote">Any particular wires I should be checking?</TD></TR></TABLE>
Being that the problem just occurred I would check the wires you were horsing around with.
Old Oct 18, 2007 | 12:02 PM
knick08's Avatar
Am I better off just taking it to a shop since I am not familiar with the wiring or is this going to be an expensive repair? The wires in this section of the car are very clustered and difficult to get to.
Old Oct 18, 2007 | 12:22 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knick08 &raquo;</TD></TR><TR><TD CLASS="quote">Am I better off just taking it to a shop since I am not familiar with the wiring or is this going to be an expensive repair? The wires in this section of the car are very clustered and difficult to get to. </TD></TR></TABLE>
it will be an expensive repair if you take it some where. i would suggest using a voltage meter if you can not find the wires with the naked eye.
but defiantely trace the path you took to run the antenna. i know looking at all those wires is intmidating, but it should be just the wires on the driver kick panel and under the steering wheel, maybe around the radio as well.
take your time, have a flashlight handy, as well as a pillow.
richboi
Sep 24, 2007 05:18 AM
1000_miles
Nov 4, 2006 11:02 PM
danteisme
Aug 5, 2004 04:29 AM
hagrid
Jan 8, 2003 01:22 PM
hydroflip
Feb 28, 2002 07:50 AM
