Aftermarket final drive for Type SH
Old Oct 18, 2007 | 10:24 AM
vinuneuro's Avatar
Default Aftermarket final drive for Type SH
What about M2Y4 and M2U4 diff's are different? For the SH, only the complete diff assembly is listed in the parts catalogs, whereas only individual parts are available for the Base. So part numbers can't be compared. The countershafts do have different p/n's though.
Old Oct 18, 2007 | 10:36 AM
vinuneuro's Avatar
Default Re: Aftermarket final drive for Type SH (vinuneuro)
It's also interesting that the helms doesn't at all discuss how to service the SH differential, and goes as far as to say not to disassemble the ring gear from the diff assembly.
Old Oct 18, 2007 | 10:58 AM
Bense's Avatar
lol i guess you could say that you're on your own on that one. Good luck.
Old Oct 18, 2007 | 11:07 AM
117's Avatar
117
I would imagine that Houseman could make one for you, but last time I checked his custom FDs were running $1,500 to $1,750, but you get to chose your ratio.
Old Oct 18, 2007 | 11:09 AM
vinuneuro's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">I would imagine that Houseman could make one for you, but last time I checked his custom FDs were running $1,500 to $1,750, but you get to chose your ratio.</TD></TR></TABLE>
Do you have any idea how the other H-series trans' and the SH trans' diffs differ?
Old Oct 18, 2007 | 12:39 PM
117's Avatar
117
Default Re: (vinuneuro)
No I do not. I've never had the opportunity to tear apart an SH trans. I do know the diff is indeed different as the driver's side has a coaxial output for the ATTS system.
Old Oct 18, 2007 | 01:07 PM
Bense's Avatar
Default Re: (117)
It would be cheaper to swap blocks + trans.
trading vehicles = easier than swapping blocks + trans
Old Oct 18, 2007 | 01:21 PM
117's Avatar
117
Default Re: (Bense)
I never said that there weren't cheaper alternatives.
There are no alternatives if you want to keep ATTS, though.
Old Oct 18, 2007 | 01:26 PM
mgags7's Avatar
The goal here is to keep atts and change the FD, I'd be in for actually finding out just what the differences are.
I'm willing to be that the size of the ring gear is near the same, hell, I don't even see why they wouldn't be identical from a manufacturing perspective.
Mayyybe the bolt pattern is different. That could be remedied though, no?
Old Oct 18, 2007 | 03:43 PM
vinuneuro's Avatar
Default Re: (mgags7)
Looking through the parts catalogs, the only differences between the Non-SH and SH transmissions seems to be countershaft, trans case and i guess the diff. All the other parts are the same. Why would the countershaft and ring gears on the diff be different? Does the countershaft come in contact with anything other than diff?
Solo2Vtec
Honda Civic (2006 - 2015)
13
Mar 23, 2007 10:50 AM
bionichicken
Apr 12, 2005 02:30 PM
SiRocket02
Jul 17, 2004 04:17 AM
zentraedityper
Dec 17, 2003 07:15 PM
