quick question about fixing leaks. please help
Go to shucks and grab a bottle of barsoil or something of that sort. Just tell them your problem and they will lead you to the stuff. I also heard of this stuff you can get at the pharmacy that is supposed to cure any head gasket leak. I dont know what it is, or if its just a rumor.
But I heard it from somewhere.
Ill google it.
Ill google it.
Heres what I came up with.....
Head gasket repair additives
Engine additives that claim to repair questionable head gaskets should only be considered a temporary fix, at best. Nevertheless, they may occasionally be used.
Common products include Bar's Leaks head gasket repair and Thermagasket. Also, sodium silicate (known also as "water glass") can be used, and it's an ingredient in some commercial head gasket repair additives. It can be found at a pharmacy. Pour a quart of it into your engine. (confirm)
