Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
quick question, Si Pulls to the left under acceleration
Old Oct 18, 2007 | 09:39 AM
jacoop86's Avatar
Default quick question, Si Pulls to the left under acceleration
okay so i was driving a 4dr Si and i noticed a huge pull to the left under acceleration. at first i thought it was the alignment, but after 2 alingments all is within spec, and it doesn't really pull when out of gear. now i'm thinking mabe differential??? what do you guys think???
Old Oct 18, 2007 | 04:51 PM
haby red fg2's Avatar
do you have 2 of the same tires(size, model, equal tread) and equal air pressure
those should be the first things checked on any car for a pull
Old Oct 18, 2007 | 05:05 PM
I:_Drive's Avatar
Default Re: (haby red fg2)
first thing that came to mind for me was tire pressure.
Old Oct 18, 2007 | 05:31 PM
ekb16's Avatar
i think there is a service bulletin on this issue..i just looked it up and if you can go to your local dealership and ask them about the Service Bulletin 06-068 Vehicle Pulling or Drifting, they might be able to help you out...they might have to replace the tire
Old Oct 18, 2007 | 08:18 PM
nsxmatt's Avatar
Only ones i've had do this at work is caused by unequal air pressure in the front tires.
Old Oct 18, 2007 | 09:38 PM
originalg00kster's Avatar
Default Re: (nsxmatt)
too much torque in these god damn Si's.
gets me everytime.
Old Oct 19, 2007 | 05:32 AM
Shiftyshadee's Avatar
Default Re: (originalg00kster)
Torque steer. That's all.
Old Oct 19, 2007 | 07:38 AM
jacoop86's Avatar
Default Re: (Shiftyshadee)
brand new bfgoodrich kdw ta 245/45/18 i believe on 18x7.5, equal tire pressure. now i'm not saying its not torque steer, but its deffinatly not normal torque steer. i'm talking normal acceleration, 1/4 to 1/2 throttle, 4-5k rpms max, and a massive pull to the left under any load. anyone else???
Old Oct 19, 2007 | 09:12 AM
ekb16's Avatar
we had a new si come in with a pull/drifting problem and one of the techs ended up having to replace a tire bcuzz it was a defect or something...take it to ur dealership and have them check it out
bsmith100
Oct 27, 2009 09:50 PM
91akira
Sep 15, 2009 04:25 PM
hotsuma23
Oct 11, 2004 03:29 PM
Daniel_san
14
Nov 8, 2003 09:43 AM
shadowdawn
Nov 5, 2002 11:21 AM
