1995 gsr longblock
Old Oct 18, 2007 | 06:16 AM
thevtecnician's Avatar
Default 1995 gsr longblock
1995 integra gsr longblock. It runs but it has low compression in one cylinder. THE MOTOR WAS NOT KNOCKING NO THROWN RODS OR BAD BEARINGS! It ran fine it just sounded like a harley lol. It needs new rings. Also its setup for obd0 meaning it has obd0 b16a injectors, obd0 driver side enigine mount bracket, obd0 vtec solenoid and pressure switch. (Has obd1 throttlebody) no dizzy, flywheel clutch etc. I will write a bill of sale for it.its setup to drop into an ef or da integra.
The bad is it has an obd0 thermostat housing which means there is no fan switch. Also the low compression.
I was going to rebuild it myself but I don't really have time for it right now. I purchased a set of p30 pistons for it which would net about 11.6:1 compression ratio with a stock headgasket. I'll throw those in with the motor if you buy it. After the rebuild, and maybe some good cams and a good header and tune you could see at least 200 whp.
$650 firm cash only. I'm not currently taking any trades unless you have a fully complete down to every last bolt quartersports h2b kit.
Its all dirty from the plastic I used to cover it.
http://s34.photobucket.com/albums/d108/theVTECNICIAN916/?action=view&current=IMG00001-2.jpg]http://s34.photobucket.com/albums/d1...IMG00001-2.jpg[/url]
http://s34.photobucket.com/albums/d108/theVTECNICIAN916/]http://s34.photobucket.com/albums/d1...IMG00002-2.jpg[/url]
Jdm dohc vtec 1.8 b18 dc2 motor ef8 ef9 ef2 ef3 da da6 da7
Modified by thevtecnician at 4:40 AM 11/8/2007
Old Oct 18, 2007 | 06:20 AM
crx_si-r's Avatar
Default Re: 1995 gsr longblock (thevtecnician)
hey im interested in just the oem b16a obdo header and down pipe. lmk cash in hand.
Modified by crx_si-r at 9:14 AM 10/18/2007
Old Oct 18, 2007 | 07:26 AM
Someone should trade me for a set of jdm 4x114.3 wheels
Old Oct 19, 2007 | 05:44 AM
Bump for da pics gee wish I had a set of regamasters in 4x114.3....... some white ones
Old Oct 20, 2007 | 03:01 AM
I know someone wants to build a gsr for cheap
Old Oct 20, 2007 | 11:15 PM
rayarea's Avatar
Anything else your wanting to trade for??
Very interested!!!
Old Oct 21, 2007 | 02:46 AM
Default Re: (rayarea)
Whatcha got? Send a pm
Old Oct 22, 2007 | 03:45 AM
Window shoppers
Old Oct 23, 2007 | 03:34 AM
Top
Old Nov 6, 2007 | 04:21 AM
Back up for sale peeps.
hk_gsrguy
Jan 12, 2012 11:38 AM
ComeOnKip
65
May 15, 2008 12:07 PM
slow91crx
May 5, 2006 07:53 AM
LD_EGSICK
May 8, 2004 09:51 PM
