suspension problem...
Old Oct 18, 2007 | 03:51 AM
white90crxhf's Avatar
Default suspension problem...
i just replaced my rear struts after 305k with some kyb agx adjustable struts, they seem worse on the weakest setting. I used the old stock coil springs on them, what's the life expectancy on a coil spring? Do i need new springs? do i need a stiffer spring?
Old Oct 18, 2007 | 05:58 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
yea stock springs are junk. the spring rates thread in the faq should help you decide what you need.
Old Oct 18, 2007 | 06:19 AM
JustAnotherRex's Avatar
Default Re: suspension problem... (white90crxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white90crxhf &raquo;</TD></TR><TR><TD CLASS="quote">i just replaced my rear struts after 305k with some kyb agx adjustable struts, they seem worse on the weakest setting. I used the old stock coil springs on them, what's the life expectancy on a coil spring? Do i need new springs? do i need a stiffer spring?</TD></TR></TABLE>
It could be the spring, you could need to up the stiffness, any numbero f other things. You're being pretty vague saying "they seem worse."
You did preload everything right?
Old Oct 18, 2007 | 07:25 AM
yes, i use my floor jack when i tighted the bolts. it's alot more bouncy and i heard a loud thump when i hit a nasty bump. i can't believe my old struts were better...
i looked at the spring rates...i dont want to lower my car, i just want a smooth ride on these crappy virginia roads.
Old Oct 18, 2007 | 07:32 AM
richmond's Avatar
Default Re: (white90crxhf)
set them stiffer? should let me drive it see and see if you installed them wrong or something. see you at the dobe!
^hahahahahahhaha
Modified by richmond at 10:07 PM 10/19/2007
Old Oct 18, 2007 | 08:04 AM
Ermil's Avatar
Default Re: (richmond)
I have my KYB AGX's on their lowest setting with H&R sport springs. Drives great. Even better now with my ST bar.
Why didnt you replace all four? You just did the backs?
Old Oct 18, 2007 | 09:01 AM
Default Re: (Ermil)
i got some shitty monroe sensa-tracs up front, thought i'd save some money with them, i was wrong. i'll be buying the front ones next month probably.
what is the dobe? i actually live south of rich. in the burg of peters.
Old Oct 19, 2007 | 04:02 AM
it seems worse when i hit a depression in the road instead of a bump, don't know if that helps...
Old Oct 19, 2007 | 09:06 PM
richmond's Avatar
hahahaha i thought you were someone else. but qdoba is a mexican restraunt. we call it the dobe. what a hilarious misunderstanding.
Old Oct 21, 2007 | 09:30 AM
well i figured out the problem, the dust boots on the HF struts are too small to fit over the base of the kyb agx! The dustboot was grabbing onto the base and not letting it go...causing a terrible ride.
I took the dust boots off and now it rides nice! question is... How long do i have before i ruin my new struts without the boots? and will dx/lx/si boots fit over the base of the kyb strut?
bad-monkey
Suspension & Brakes
Feb 17, 2016 07:06 AM
harmonator84
Mar 10, 2007 08:44 PM
91DA
Apr 30, 2005 03:28 PM
hatchback_al
12
Jun 20, 2004 05:32 PM
Henry HA
Jun 4, 2003 06:30 AM
