Brake Line Popped! Can I Pinch The Brake Line To Get My Car Home?
So my drivers side rear brake line must have popped or something, I hit the brake pedal while driving and I lost all pedal feeling, pulled over and pumped the brakes and there was a good puddle of fluid under that brake.
Is there a way to just pinch that brake line or isolate it from not gettin fluid somehow?
I just need ti make it home about 2 miles
The car has a teggy rear disc conversion if it matters.
Thanks guys
Thanks guys
I've done it with a needlenose vicegrips. Gotta leave em on there while you drive it home.
Drive slowly, keep as much distance as posssible between you and other cars, use your handbrake and engine braking to slow
Don't forget to take plenty of brake fluid to fill up/top off your resivoir. If you're very carefull you should be fine, I wouldn't take it on the highway or anything though, unless absolutely necesary.
You have more mechanical problems than anyone else in this forum that I know of.......get rid of that car and find another one....
and no don't tattoo this CRX on ur butt like ur avatar states or it might give u mechanical problems.LOL just get rid of this car and get a better one
happened to me. just used downshifts and ebrake. i had to go about 10 miles too. put my flashers on and drove about 25 the whole way home. with no pedal whatso ever
PINKS
Oct 18, 2007 06:04 AM
PINKS
Oct 18, 2007 05:11 AM
