Tail light not working
Longshot, but have you checked the bulbs? If thats not it I would assume that it is a bad gorund or bad resistance somewhere. There are a lot of grounds for the rear lights under the back plasic panel.
Hope that gets you started on finding the solution.
Bump for more answers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmrCRX »</TD></TR><TR><TD CLASS="quote">Did you check fuses?</TD></TR></TABLE>
I would think that if it was a fuse that all the rear lights would stop working. I dont think they switched circuits for left and right sides. Like if you blow the instrument panel fuse (gauge cluster lights) the taillights will go out too.
So I dont think it would be a fuse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OversteerMotorSports »</TD></TR><TR><TD CLASS="quote">Longshot, but have you checked the bulbs? If thats not it I would assume that it is a bad gorund or bad resistance somewhere. There are a lot of grounds for the rear lights under the back plasic panel.
Bump for more answers. </TD></TR></TABLE>
listen to this guy its not a fuse its your bulb or a short
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie »</TD></TR><TR><TD CLASS="quote">
listen to this guy its not a fuse its your bulb or a short</TD></TR></TABLE>
Thannnnggggggggs lol
And my guess, if both bulbs are bad, you have a short or a wire arching out. If the bulbs are good however, its a bad ground.
Thannnnggggggggs lolAnd my guess, if both bulbs are bad, you have a short or a wire arching out. If the bulbs are good however, its a bad ground.
1sikcoupe
10
May 7, 2004 03:23 PM
