RPM goes CRAZY after 5K
here is my situation.. if i full throttle and the rpm goes pass 5k, right after that it starts jumping like crazy back and forth... the cluster is a jdm itr cluster, motor is a b20vtec, and i'm using a obd2a distributor (98 gsr)... i swapped out the jdm rpm, km's, fuel, and what not with the usdm stuff.. also the distributor, i noticed that the blue wire is there and missing from the engine harness.. the motor does not have a crank sensor and i am running a jumper 0bd2b-obd1. i'm not sure what the problem is. can it be the cluster or the distributor due to the missing blue wire on (i believe) all 00-01 integra.. i don't know if any of you guys have this problem or experienced this.. any input is greatly appreciated.. thanks
Your problem is in your obd2b to obd1 jumper.
You need to contact whom ever you bought the harness from and get a "modified" version of the jumper specifically for your tach issues.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">Your distributor may be giving out....</TD></TR></TABLE>
very good chance...as this just happend to me... mine would jump around spratically from time to time (at least 2 times a week) did this for about a month & a half. Until one night while driving on the freeway, i lost power for a second or two doing 65mph, power came right back...so i exited, put some city mileage on, and couldn't find anything wrong underhood, after driving around for another couple hours, it started to cut in and out alot and finally gave out on me, ended up being the coil in the distributor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs »</TD></TR><TR><TD CLASS="quote">Your distributor may be giving out....</TD></TR></TABLE> crazy, might be your speed sensor
that's the same thing that is happening to the car.. i would cruise and all of a sudden the car would just lose power and slow down and pick back up.. and i used the 2001 integra green film in the back of the cluster as well.. thanks for the input..
the speedo works fine.. car drives fine but just the RPM jumps back and forth.. like crazy back and forth.. power is fine but i think it might be something with the missiog blue wire on the engine harness that connects to the distributor..
hello i have the same sort of problem and was wounderin if u all could help. i have a b18c5 in a civic coupe dx and it ran perfect untill i decided to change the cams. so after i change the cams it tries to hit vtec but it cuts off like a fuel or spark cut off, not a rev limit. it just looses power. also my non aftermaket rpm gauge is going crazy it will somtimes just go crazy and shot throu all the rpm ranges. i have compression checked it and adjusted the valves and tuned it a little. but i was woundering if anyone had any ideas. thanks a lot.
we should start a support group...
hi im colin, and my TACH hates me.
seriously mine does the same damn thing. what part for DIZZY should i buy? im using a OBD2b to obd2a kingmotorsports jumper but when i use an obd2b ecu it does the same thing jus less. the RPM goes crazy then dies at zero.
I'm Fang... my TACH doen't like me when i abuse it..
my problem seems to be a lot of people's problem as well.. so we must band together as itr brothers and find a cure.. ARE YOU WITH ME!...
its your ignition control module.. i had the same problem with my car 95 coupe with a 97typer motor with obd2 dizzy.. (dont even ask i didnt do the swap).. i swapped the icm out and it was all good
