My heat isnt working
Hey people all my temp controls stopped working couple days ago and I dont know why. None of the lights go on, and I checked all the fuses. Could the reason nothing works be a vacuum problem? And about the lights....... I installed a vacuum guage on it like last week, thats why I think vacuum might be playing a part.. Anything?
Since you posted 'My heat isn't working' let's start there. I'm assuming the blower motor is working and air is coming from the vents. Have you checked the cable that controls the heat switch in the engine compartment to make sure it's working?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVTECB20HB »</TD></TR><TR><TD CLASS="quote">I installed a vacuum guage on it like last week, thats why I think vacuum might be playing a part.. Anything?</TD></TR></TABLE>
If you also hooked your gauge to a power source, you might want to look at the fuse that power source is attached too. You could have shorted the circuit and blew the fuse.
Just my .02
Just my .02
Where's that located....I'm looking for mine to check and see if that's happen to mine cuz...the heat's not working. Turn ON only fell air coming but not hot. Beside that, I can't move the heat temperature to the red side, its stuck in the middle. Any help?
Thanks
Thanks
SpeedOFsmell
Mar 15, 2014 06:14 AM
