My heat isnt working
Hey people all my temp controls stopped working couple days ago and I dont know why. None of the lights go on, and I checked all the fuses. Could the reason nothing works be a vacuum problem? And about the lights....... I installed a vacuum guage on it like last week, thats why I think vacuum might be playing a part.. Anything?
Re: My heat isnt working (IVTECB20HB)
Since you posted 'My heat isn't working' let's start there. I'm assuming the blower motor is working and air is coming from the vents. Have you checked the cable that controls the heat switch in the engine compartment to make sure it's working?
Re: My heat isnt working (iluvmyhnda)
Im sure the cable just fell off. My DD accord has the same problem. If the cable isnt clicked in the tab all the way, it will just fall off.
Re: My heat isnt working (OversteerMotorSports)
if its all your controls, open it up and see if you are getting power to the switches. check your fuses and relays
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVTECB20HB »</TD></TR><TR><TD CLASS="quote">I installed a vacuum guage on it like last week, thats why I think vacuum might be playing a part.. Anything?</TD></TR></TABLE>
If you also hooked your gauge to a power source, you might want to look at the fuse that power source is attached too. You could have shorted the circuit and blew the fuse.
Just my .02
Just my .02
Nothing at all is working none of the lights are on, none of the vents are moving....... and the fan isnt moving at all
Re: My heat isnt working (RIZOBIZERT)
Where's that located....I'm looking for mine to check and see if that's happen to mine cuz...the heat's not working. Turn ON only fell air coming but not hot. Beside that, I can't move the heat temperature to the red side, its stuck in the middle. Any help?
Thanks
Thanks
SpeedOFsmell
03-15-2014 06:14 AM
