95 GSR rear disc question
bout to get some for my 98 cx hatch. They come with trailing arms and e-brake cables. read something bout having to get 99-00 si cables or somethin is this true or is what im gettin all that i need?
for a hatchback, you can use the integra ebrake cables, but it'll be a bit long and you wont be able to bolt it up
you only use 99-00 civic si ebrake cables if you're installing rear disc onto a coupe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">
you only use 99-00 civic si ebrake cables if you're installing rear disc onto a coupe</TD></TR></TABLE>
Incorrect! You can use the 99-00 Si e-brake cables for a hatch/coupe/sedan. I have done this swap a few times, the last time was on my hatch and the Si e-brake cables are a perfect fit.
818SpoonITR
Nov 1, 2006 12:06 PM
