IAT cel 10 help??? gsr motor
Old Oct 17, 2007 | 06:21 PM
BoostnEK6206's Avatar
Default IAT cel 10 help??? gsr motor in 96 hatch
i swear i have checked everything still throwing code. resistance of the sensor, continuity to the right pin of the ecu from the sensor, took the sensor out and cleaned it with electrical stuff. and the motor was taken out to be built and worked fine before that just now on re-installing it is throwing the code
the iacv and iat are NOT mixed up its a intake manifold mounted iat!
Old Oct 17, 2007 | 07:21 PM
Inliner's Avatar
ya i had my IACV and IAT switched for one start and fried the IAT just go to a junk yard and get a new one prolly wont even charge you.
Old Oct 17, 2007 | 07:28 PM
Default Re: (Inliner)
put a new sensor in and now it doesnt throw the IAT jus the IACV
Old Oct 17, 2007 | 07:32 PM
imptricer's Avatar
Default Re: (BoostnEK6206)
this is weird that now it would throw the iacv? im glad it was the sensor cause seriously i check everything i could but changing the sensor
Old Oct 17, 2007 | 07:36 PM
Default Re: (imptricer)
ya and if we swap the clips then it those the IAT so vis versa.
Old Oct 18, 2007 | 09:38 AM
bump^^^^ it stopped thrown the iat code 10 and now is thrown code 14 which is iacv
Old Oct 18, 2007 | 10:53 AM
i.'s Avatar
i.
sounds like the same things that were happening to my motor, same codes as well.
turnede out to be my TPS needed adjustement, as well as the idle. check this post, might help rule things out.
https://honda-tech.com/zerothread/2127246
mixmastabob
Aug 20, 2004 07:29 PM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
12 oz.
Jun 3, 2002 04:05 PM
