Suspension & Brakes Theory, alignment, spring rates....
Sway bar problem
Old Oct 17, 2007 | 06:15 PM
mullet eater's Avatar
Default Sway bar problem
I tried searching nothing came up!
I tryed putting a 99 type r front sway bar on my 97 ek hatch back everythang bolted up ok but when i lowered the car down i got in it to test drive it and grabed the shifter and it was real bound up hard to move. So i raised the car back up and it looked like the sway bar was hiting the shift linkage its pretty bad i cant hardly put it in gear at all. So i took it off but im trying to figure it out? everything was right i didnt put it in wrong i know for shure! Its also the stock motor and shift linkage.
thanks for any help you can give
Old Oct 17, 2007 | 07:09 PM
BlueIntegraBoy's Avatar
Default Re: Sway bar problem (mullet eater)
Other people have fixed this problem by mounting the endlink below the LCA as opposed to above it. It hangs lower, but does not affect shifting.
Old Oct 18, 2007 | 09:24 AM
92civeg's Avatar
Default Re: Sway bar problem (BlueIntegraBoy)
stock motor?, thats funny this post says you have a b swap,....who u trying to kid you simp
https://honda-tech.com/zerothread?id=2106190
3K_Hatch
Dec 17, 2017 12:31 PM
WideBodyFEELZ
10
Jul 13, 2015 02:03 PM
WideBodyFEELZ
Suspension & Brakes
14
CRX MASE
Feb 16, 2011 11:06 PM
nahonda04
12
Sep 15, 2008 03:00 AM
