Testing waters: Sparco Pro 2000 Racing buckets and a b18c1 swap
Old Oct 17, 2007 | 01:50 PM
cnydc2's Avatar
Default Testing waters: Sparco Pro 2000 Racing buckets and a b18c1 swap
Well I never thought that I would consider selling this stuff but that time has come. Im currently in going to school FT for electrical engineering and money has become tight. Not to mention my needs for a more comfortable and larger vehicle have arose.
First off a pair of Sparco Pro 2000's with sliders and Sparco mounting brackets for Integras and Civics. the seats are black in color and were only used for one summer season. They are in great coondition. The only flaw that I can recall is a small, maybe the size of a quarter, blotch of expanding foam on one seat. I worked a little to remove it but gave up, I do plan on working more on it before they are sold. They come with all padding and complete hardware. These seats retail for over $1200 a pair w/o brackets, I will be offering them for $850
SORRY FOR THE SPOTS ON THE PICTURE, I DIDN'T CATCH IT UNTILL AFTER THE PIC WAS TAKEN. I WILL GET A NEW ONE THIS WEEKEND
HERE IS THE SPOT ON THE DRIVER SEAT
THIS IS THE RIGHT HARNESS HOLE ON THE PASSENGER SEAT, THE BOTTOM LEFT CORNER BROKE OFF
Second up is my B18c1 project that I was building for my current Civic. I've really ran out of time to even consider finishing the assembly. The block was removed from a freinds GS-R with about 115k on the clock. I had the block hot tanked and honed out to accomidate the new pistons.
<U>Block Parts List</U>
JDM ITR oversized pistons (.25 was written on box)
Pistons are already attached to oem GS-R rods
An uninstalled set of ARP rod bolts
ARP head studs (I'm missing some of the washers and nuts for these)
Oem crank
Oem oil pan
All girtles
All squirters
All hardware to reassemble will be included
<U>Cylinder Head Details </U>
Hot tanked
3 angle exhaust and 4 angle intake valve job
Brand new SuperTech Valves
Brand new Rocket Motorsports Gen 2 valve springs (Huge Seat Pressure)
Brand new Rocket Motorsports Gen 1 Ti retainers
Brand new OEM Honda Guide seals
Set of brand new ST Corsa Cam gears
The head has been fully assembled and will include all rockers and a pair of OEM GS-R cams.
The engine will also include the OEM valve cover, a 1 year old distributor, a set of MSD ignition wires, and all the gaskets and seals needed for assembly.
<U>What Is Needed Finish Engine</U>
Timing Belt
All bearings
Piston Rings
New Oil pump
Washers and Nuts of ARP headbolts
<U>Transmission</U>
Unit off a B18c1 with 150k on clock
No grinds
Shifts great
All shift linkage is included
OEM axles
Uberdata Chipped P72
ASKING $2800
Well I think that is all I can think of right now. If I missed anything of you have any questions please post em up. I don't have picture of anything yet, but I will try to go home and get some this weekend. All of this is best offer and I will entertain just about anything, just pm me what you are thinking. This engine setup should yeild about 11.5-7 compression and should be capable of 10k+ rpm.
Please Bump if you look, Thanks
Modified by cnydc2 at 4:22 PM 11/14/2007
Modified by cnydc2 at 4:24 PM 11/14/2007
Modified by cnydc2 at 4:26 PM 11/14/2007
Modified by cnydc2 at 6:26 PM 11/15/2007
Old Oct 18, 2007 | 05:22 AM
cnydc2's Avatar
Default Re: Testing waters: Sparco Pro 2000 Racing buckets and a b18c1 swap (cnydc2)
Bump it up
Old Oct 22, 2007 | 12:29 PM
cnydc2's Avatar
Bump
Old Oct 22, 2007 | 05:25 PM
cnydc2's Avatar
Off to do some HW
Old Oct 24, 2007 | 09:02 AM
cnydc2's Avatar
Have pics up this weekend
Old Oct 24, 2007 | 06:00 PM
1995Civiccx's Avatar
pm'd
Old Oct 24, 2007 | 06:23 PM
Markland Photo's Avatar
do you happen to have pictures of the seats? and the damage on the seat? ill hit you up about the motor
Old Oct 25, 2007 | 07:28 AM
cnydc2's Avatar
Default Re: (Markland Photo)
I'm going to get some pics of the seats and motor when I go home this weekend. I'll let you know when I get them posted up
Old Oct 29, 2007 | 12:21 PM
cnydc2's Avatar
bump it up
Old Oct 30, 2007 | 04:06 PM
cnydc2's Avatar
Might be willing to part the swap out
Old Nov 5, 2007 | 04:26 PM
cnydc2's Avatar
Got some pics....will post em soon
Old Nov 14, 2007 | 12:28 PM
cnydc2's Avatar
Pictures are finally up. The seats are a lil dusty, I'll try to get to vacuuming them up and get some new pics
Old Nov 15, 2007 | 04:59 AM
cnydc2's Avatar
Bump
Old Nov 19, 2007 | 12:12 PM
cnydc2's Avatar
Bump it up
Old Nov 19, 2007 | 12:58 PM
silentryda's Avatar
i need the pasenger seat i already have the driver one.figures u have both.dam it.
Old Nov 20, 2007 | 08:28 AM
cnydc2's Avatar
Default Re: Testing waters: Sparco Pro 2000 Racing buckets and a b18c1 swap (silentryda)
PM me and maybe we can work something out
Old Nov 26, 2007 | 11:59 AM
cnydc2's Avatar
bump
cnydc2
Mid-Atlantic (Sales)
14
Dec 3, 2007 12:55 PM
da'ee
Apr 12, 2005 05:16 PM
TypeR Chris
Jul 2, 2003 02:22 PM
