noob help. K24 swap and ECU (I searched!)
Old Oct 17, 2007 | 01:00 PM
Grandprix's Avatar
Default noob help. K24 swap and ECU (I searched!)
I'm looking at buying an EP that has a stock K24A1 and a hondata Si reflashed ecu. I looked all over the internet and hondata's website, but cannot find any information regarding this motor and ECU combination. I even emailed Hondata and they said they don't do reflashes for motor swaps (wtf?). They said the ECU would be a reflashed ECU for the Si motor.
So basically what does the reflash do? Can I just pop in a stock K24 ecu? Is the reflashed Si ECU safe for a K24A1?
Help!
Old Oct 17, 2007 | 04:50 PM
Master23's Avatar
Default Re: noob help. K24 swap and ECU (Grandprix)
Get Kpro, you can program the ECU to run your K24a1. The reflash is a basic tune for bolt ons like I/H/E. Look on Hondata.com for more info about reflash.
Old Oct 17, 2007 | 07:10 PM
88da3's Avatar
why not op for a k24a2?
Old Oct 18, 2007 | 11:31 AM
Grandprix's Avatar
Default Re: (88da3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">Get Kpro, you can program the ECU to run your K24a1. The reflash is a basic tune for bolt ons like I/H/E. Look on Hondata.com for more info about reflash.</TD></TR></TABLE>
Car already has reflashed ECU. Hondata says they don't reflash ECUs for K24A1. That's why I don't understand how this thing has been running for 45k miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88da3 &raquo;</TD></TR><TR><TD CLASS="quote">why not op for a k24a2?</TD></TR></TABLE>
Car already has a K24A1.
I see a CRV ECU for sale in my city. I guess I'll have to throw the car on the dyno to see how it's running, and then make a decision based on that.
Old Oct 18, 2007 | 01:39 PM
Master23's Avatar
Default Re: (Grandprix)
Thats why you have to get kpro to program the ECU to run the K24a1 properly. Thats the only way that I can think of.
Old Oct 19, 2007 | 10:00 AM
WyldRice's Avatar
IMHO-
You NEED a engine management program that works FIRST!
without it, you may have this!
http://www.youtube.com/watch?v=iOcqMOSvpRI
NASTY!!!
<U>582WHP</U> K20 ENGINE
-Supposed to be boosted up to 35psi...
Engine management was wrong...
Blew motor at 42 PSI... BOOST cut-off Didn't work!
escentially,
KPRO will be needed or you will end up with that!
...poor bullfrog! someone said that was his 3rd engine! Damn!
Old Oct 19, 2007 | 10:06 AM
WyldRice's Avatar
Default Re: (WyldRice)
sorry- he was trying to boost to 30psi- not 35...
but my point here is, you don't need a k24, so you dont see them very often.
i was told by my tuner, that i should get the k24 when i bought my ep3...
i looked into it... TOO MUCH HASSLE! - and changing everything out is very expensive!
if i wanted a bigger engine and had the money, i'd put the viper engine in it, and rear wheel drive!
i'd then need a real frame and roll cage...
you could get stupid silly on modding them... but for what?
they're great DD's as they are, plus you CAN get away with some nasty WHP if you need it!
Old Oct 19, 2007 | 10:59 AM
WhiteOnRice's Avatar
Please change your avatar.
Old Oct 19, 2007 | 01:38 PM
Grandprix's Avatar
Thanks for not even reading the thread WyldRice
Old Oct 19, 2007 | 06:07 PM
WyldRice's Avatar
Default Re: Gran ****** (thats how i pronounce it)
nah man, i did... now you, read the responces!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master23 &raquo;</TD></TR><TR><TD CLASS="quote">Get Kpro, you can program the ECU to run your K24a1.</TD></TR></TABLE>
Again- (IMHO means- In My Humble Opinion!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">IMHO-
KPRO will be needed </TD></TR></TABLE> or you will end up with a video like the you tube!
but to answer your question in an other way...
if you use the stock K24 ECU, you'll be fine!
sorry for trying to help
...Good luck with the dumbest swap ever! (that's why you don't see it often!)
(Hey you gain no HP, But at least you'll have a little more torque, Right?)
Old Oct 22, 2007 | 04:44 AM
Grandprix's Avatar
Default Re: Gran ****** (WyldRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WyldRice &raquo;</TD></TR><TR><TD CLASS="quote">
if you use the stock K24 ECU, you'll be fine!</TD></TR></TABLE>
Thanks!
(Hey you gain no HP, But at least you'll have a little more torque, Right?) </TD></TR></TABLE>
Seriously, re-read the original post.
Old Oct 22, 2007 | 04:51 PM
WyldRice's Avatar
Default Re: Gran ****** (Grandprix)
lol JUST get the k-pro!
Modified by WyldRice at 4:26 PM 10/23/2007
Old Oct 23, 2007 | 11:40 AM
Grandprix's Avatar
awesome you finally got it, but I'm confused on your statement about EP and not EP3. This is the DC5/EP3 forum, right?
My EP3 (2003 Honda Civic Si) already has a K24. Well it appears to do fine. I practically stared at the AF gauge as I drove home. The iVTEC is weird with the lean burn mode while coasting. But it was basically almost always rich and sometimes hitting the stoich area of the gauge. So that puts me at ease. Don't know how the ECU works with the K24, but I guess it does. Maybe the computer was able to learn?
KPro would be nice, but this thing is going to be my daily driver beater. The fully modded 240 is the fun car (and boy is it fun!).
Old Oct 23, 2007 | 11:44 AM
k20 head, Kpro, tune and be done with it.
Old Oct 23, 2007 | 01:25 PM
WyldRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandprix &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking at buying an EP that has a stock K24A1...</TD></TR></TABLE>
ok, here is where YOU have Everyone confused...
i thought you may have an EP4! or EP5!
BECAUSE- if it is an EP3....
Heres the good part!-
YOU DON'T HAVE A STOCK MOTOR...
NO K24's came "Stock" in an EP3!
(You understand this, correct?)
1. If you understood that, REREAD your own post... it makes no sence!
2. and Please Don't say "Well the motor wasn't modded, so that means it's stock..."
AS SOON AS ANY <U>K24 is PULLED OUT OF A VEHICLE, IT becomes NOT STOCK</U>!
no matter what ecu or mod's you have or haven't done!
now...
How can i help you?
Old Oct 23, 2007 | 01:41 PM
ep3hatchSi's Avatar
Default Re: noob help. K24 swap and ECU (WyldRice)
I have a ep3 with a k24a1 in it.
You need KPRO! Run a k20a3 kal and just add 10% fuel to your tables.
thats all u need
Old Oct 23, 2007 | 02:06 PM
WyldRice's Avatar
Default Re: noob help. K24 swap and ECU (ep3hatchSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3hatchSi &raquo;</TD></TR><TR><TD CLASS="quote">I have a ep3 with a k24a1 in it...</TD></TR></TABLE>
That's the stock one, right?
muahhahha!
...sorry, i had to!
Old Oct 23, 2007 | 04:29 PM
ep3hatchSi's Avatar
muahhahha!
...sorry, i had to! </TD></TR></TABLE>
lol man if ep3's came stock with k24's... that would be niceeee
ekgsr98
Jul 24, 2010 12:37 AM
Rocks
Aug 30, 2004 05:14 PM
gr8bigbox
Jun 8, 2004 09:54 PM
straightline
Nov 13, 2002 06:52 AM
