gsr mix & match
Old Oct 17, 2007 | 10:59 AM
crave13k's Avatar
Default gsr mix & match
hi i was just wondering if it was possible to use ls parts on my gsr tranny if any. please help.
Old Oct 17, 2007 | 12:26 PM
b18LS's Avatar
Default Re: gsr mix & match (crave13k)
As long as their both hydro tranny's, I THINK, all b series gears are interchangeable. If youre getting rid of your gsr gear set, let me know!
Old Oct 17, 2007 | 12:34 PM
hatchling37's Avatar
There are plenty of parts that will swap directly over. What are you doing, changing synchro sets? The only differences are 3-5 gear ratio and the final drive.
Old Oct 17, 2007 | 12:42 PM
dsnyder305's Avatar
You can change all gears form one b series tranny to the next as long as both are hydraulic/cable and as long as you have both the main gear and the countershaft gear.
Old Oct 18, 2007 | 07:12 AM
crave13k's Avatar
Default Re: gsr mix & match (dsnyder305)
well the reason i want to change some stuff out is because some of the parts from the tranny are bad. the problem that i was having is that after i had a quife lsd installed i couldn't downshift. i didn't figure this out till like two weeks after i had it installed. one day i was on the fwy and an sti starts reving his engine and i was on fifth just cruising, so i tried to downshift (for the first time after i had the lsd installed) and i got a nasty *** grind. i mean it wouldnt even go into third. it felt like if i just tried to put it in without stepping on the clutch. well what i ended up doing is reving the engine to like 5k rpm in order for the gear to go in smoothly. i later figured out that i had the same problem going from 5-4 and 4-3. 3-2 were basicly the only gears to go in smoothly. so i took it back to the guy who installed the lsd and told him that the tranny was all jacked up. he opened it up and said that the tranny had taken a beating (not true) and he said it was because i forced the gears in very hard too many times (NOT true). so he concluded that the sliders (whatever that is) are messed up and i think the synchros. so please help. if i could get the parts from an ls then i will. its a hydro tranny by the way. thks and sorry its so long.
Old Oct 18, 2007 | 07:29 AM
Dogginator's Avatar
Daisy... Daisy...
Did you check the transmission fluid level? Any leaks?
Old Oct 18, 2007 | 07:35 AM
DC209's Avatar
i just swaped some parts of my LS to GSR they work good luck
Old Oct 18, 2007 | 07:37 AM
crave13k's Avatar
Default Re: gsr mix & match (Dogginator)
i made sure it had enough oil before starting it up. i might also add that i had to shift slowly because if not i would get a little gring and i didn't like it. i was told to mess with the clutch pedal and adjust it. but i guess the whole time it was just the tranny. so what parts can i take from an ls and put in my gsr?
Old Oct 18, 2007 | 07:50 AM
all-mtr-teg's Avatar
PM "bense" he's the tranny gury Or check this out
https://honda-tech.com/zerothread/1922582
Modified by all-mtr-teg at 11:43 AM 10/18/2007
Old Oct 18, 2007 | 01:10 PM
crave13k's Avatar
Default Re: gsr mix & match (all-mtr-teg)
i im'd him but i haven't got a response.... any one else willing to help?
linkdeezie
Transmission & Drivetrain
18
Feb 4, 2019 07:34 AM
atm_integra
Feb 14, 2010 05:08 AM
CrxEDguY
11
Aug 4, 2004 11:58 PM
Full-Race Henry
12
Sep 12, 2003 11:49 PM
johnzm
Oct 5, 2002 12:15 AM
