Redline MT-90 - Good for Integra?
Old Oct 17, 2007 | 10:49 AM
daonei's Avatar
Default Redline MT-90 - Good for Integra?
Hey guys,
Just picked up Redline MT-90 at Super Autobacs, but is this product good for Integra trannys? And is two quarts enough?
Old Oct 17, 2007 | 10:57 AM
LSEGHATCH's Avatar
Default Re: Redline MT-90 - Good for Integra? (daonei)
I've always used Honda MTF. Though Redline is a reputable product, I don't see why you couldn't use it, just make sure you get the proper weight.
Old Oct 17, 2007 | 11:07 AM
daonei's Avatar
Default Re: Redline MT-90 - Good for Integra? (LSEGHATCH)
yah, not sure if this was the right one. it says it satisfies requirements for 75w, 80w, and 90, but anyone have any knowledge?
i think i should have picked up mtl, but will mt-90 work as well?
Old Oct 17, 2007 | 11:22 AM
iH8RICERZ's Avatar
I've used Redline (dont think it was the MT90) in my gsr trans....and at first, it was nice...BUT, I noticed it was harder to get into gear when the car was cold. I also think it did more damage than good. Used gm sychromesh and it was a night and day difference! Honda MTF and gm synchromesh is what i recommend.
Old Oct 17, 2007 | 12:22 PM
b18LS's Avatar
Redline products are very good. Make sure you check the website though, use their product application guide for your car, and it'll tell you what weight is safe for your tranny. I'd be a bit cautios using anything other than MTF or synchromesh on our transmissions though. Double check to make sure. If you want to experiement try it, if it gets harder to shift, try amsoil synchromesh. It is really nice stuff.
Old Oct 17, 2007 | 12:29 PM
hatchling37's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daonei &raquo;</TD></TR><TR><TD CLASS="quote">yah, not sure if this was the right one. it says it satisfies requirements for 75w, 80w, and 90, but anyone have any knowledge?
i think i should have picked up mtl, but will mt-90 work as well? </TD></TR></TABLE>That ****'s gear oil. Get their equivalent of 10w30 or 10w40, or go with Synchromesh. The Pennzoil version is far cheaper than both GM and Amzoil.
Old Oct 17, 2007 | 12:31 PM
lmike6453's Avatar
honda mtf....2.3 quarts
Old Oct 17, 2007 | 12:59 PM
Dc2 Joe's Avatar
Default Re: (lmike6453)
never tried that but i have gm synchromesh and love it
Old Oct 17, 2007 | 01:09 PM
Padawan's Avatar
Darth ModerVader
Red Line recommends the MTL for use in Honda transmissions, though I personally would use standard Honda MTF. Either way, MT-90 is not the stuff you want.
Old Oct 17, 2007 | 01:17 PM
skunked's Avatar
Default Re: Redline MT-90 - Good for Integra? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Red Line recommends the MTL for use in Honda transmissions, though I personally would use standard Honda MTF. Either way, MT-90 is not the stuff you want. </TD></TR></TABLE>
Old Feb 29, 2016 | 04:52 PM
Redline_77's Avatar
It shows it can be used in transaxles that use the consistency of 10w40 so I see no problem
Old Feb 29, 2016 | 08:57 PM
MotorMouth93's Avatar
10 Year Member
I used that stuff for about a year in my Integra, hoping it would help save my 3rd gear synchro. Over that year it went from mild grinding when shifting fast high in the rev range to almost unusable, I could barely shift into 3rd over 2000rpm without grinding.
Then I changed it out for Honda MTF and the grinding almost stopped entirely, I gotta wonder what shape my transmission would be in now had I just gone straight for the MTF.
Lesson learned.
Old Mar 3, 2016 | 12:02 PM
TOO MUCH TORQUE's Avatar
75w-90 is THICK and doesnt flow well. 75w-90 is for differentials.
Amsoil MTF is the best trans oil ive used on my integra. It's a bit pricey at between 13-15 a quart but worth it. I change mine in 50k intervals and the fluid is still nice and golden when drained.
Whatever you get, you need 3 quarts. If the car is leveled correctly, only about 2.3-2.5 will go in.
94IntegraLs04
Oct 10, 2004 02:42 PM
HuskerHybrid
12
Apr 30, 2003 06:51 AM
slowacura
Aug 19, 2002 09:36 AM
Dirt
Jun 20, 2001 10:14 PM
