NO speedometer or Vtec???
Old Oct 17, 2007 | 10:24 AM
P12 EG6's Avatar
Default NO speedometer or Vtec???
How is this possible???? what controlls the speedometer ? is it the plug in the tanny???
Old Oct 17, 2007 | 10:27 AM
97Ej6mike's Avatar
Theres a sensor called the VSS, vehicle speed sensor. If its broken, VTEC will not engage, ECU thinks you are in nuetral.
Old Oct 17, 2007 | 10:29 AM
P12 EG6's Avatar
Default Re: (97Ej6mike)
where do you find the vss at?
Old Oct 17, 2007 | 10:34 AM
RACEPAK's Avatar
Default Re: (P12 EG6)
on the transmossion, inder the intake arm,
Old Oct 17, 2007 | 10:39 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Theres a sensor called the VSS, vehicle speed sensor. If its broken, VTEC will not engage, ECU thinks you are in nuetral.</TD></TR></TABLE>
X2
Old Oct 17, 2007 | 10:48 AM
swifty4u's Avatar
Default Re: (AWD Terror)
you have a 254 hp rhd hatch yet dont know about a vss...
Old Oct 17, 2007 | 10:51 AM
P12 EG6's Avatar
Default Re: (swifty4u)
i know there was a sensor i didnt know what it was called..... its the one on the front of the tranny not the plug toward the rear correct
Old Oct 17, 2007 | 11:35 AM
B18CUL8R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P12 EG6 &raquo;</TD></TR><TR><TD CLASS="quote">i know there was a sensor i didnt know what it was called..... its the one on the front of the tranny not the plug toward the rear correct</TD></TR></TABLE>
bro just STOP right there before i lost my mind...............
you have a 254whp hatch and you think the vss is on the front of the tranny?
the sensor on the bottom front of the tranny is for the reverse sensor
the sensor on the top rear of the tranny, passenger side of the rear t-bracket is the vss sensor. the plug faces straight down.
you can use just about any b or d series vss if im not mistaken.
im not an expert but i did stay at a holiday inn express last night
Old Oct 17, 2007 | 11:38 AM
97Ej6mike's Avatar
Default Re: (B18CUL8R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CUL8R &raquo;</TD></TR><TR><TD CLASS="quote">you have a 254whp hatch and you think the vss is on the front of the tranny?
probably bought, not built
Old Oct 17, 2007 | 12:00 PM
Bejita's Avatar
It's right on top of the passenger side of the tranny. It's black with a plug going into it. Swap it out....Everything will work again.
Old Oct 17, 2007 | 12:14 PM
MySelfAffliction's Avatar
probably bought, not built </TD></TR></TABLE>
x2
Old Oct 17, 2007 | 01:53 PM
P12 EG6's Avatar
Default Re: (MySelfAffliction)
kewl thanks,, no not bough built with a little input from larry at endyn
Old Oct 17, 2007 | 02:58 PM
NismoGriff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P12 EG6 &raquo;</TD></TR><TR><TD CLASS="quote">kewl thanks,, no not bough built with a little input from larry at endyn</TD></TR></TABLE>
Like he "input" the whole motor into the car? LOL J/K A Lot of times, the clips on the VSS plug get broken and they will stay on but can wiggle loose. Hope you figure out your problem.
Old Oct 17, 2007 | 03:06 PM
Ex-Eg-Driver's Avatar
my VSS doesnt work....then again I dont have VTEC...haha
vicki
12
Oct 22, 2008 10:26 AM
HONDRETTI
Nov 20, 2007 10:25 AM
iTzKeviN
Aug 12, 2005 01:10 PM
686_ef
11
Apr 6, 2005 05:57 PM
RAS Motorsports
Oct 15, 2004 10:44 AM
