neg camber on not lowered dc
Sup guys, Its weird. My car isnt lowered but my rear tires are cambering. I noticed about 8 months ago so I got an alignment at the dealer since I work for Acura. After I rotated my tires and the problem still persists. My friend told me that it could be because your struts are worn... is he right? how can I fix it?
Your car does not have struts. The shocks/springs should not produce negative camber unless the springs are sagging. Check for bad suspension arm bushings or bent arms. I assume that no camber kit was installed on this vehicle.
supratt
Jan 23, 2002 04:04 PM
