timing problem
hey guys sup i have a problem supposably i have the intake cam retarded and my dizzy is retarded too its all the way to the back so how can i fix that ???thanks
1. Set both cam gears at ZERO.
2. Set the crank pulley to line up at TDC with the timing mark lined up with the indicator mark on the lower timing cover
3. Now make sure the marks on each cam gear are pointing directly at each other
If the cam gear marks don't like up with the crank at TDC then you need to slide the timing belt off, line the cam gears up, then slide the belt back on
UCDags06
22
Feb 12, 2014 04:42 PM
civiccoupe94
Jan 11, 2008 07:08 AM
I8ayellowcrayon
Dec 27, 2004 07:51 PM
MikeTV
Sep 28, 2004 03:00 PM
