car has no spark!
Old Oct 17, 2007 | 08:13 AM
j-specB20sol's Avatar
Default car has no spark!
ok so i am throwing a stock b20 back into my del sol and i am hooking all the harnesses back up and i get to the distributor... wont fit! the one on the motor is a single connector and the wiring harness has two connectors, one with two big wires and one with like 7 wires i think. so like an idiot i cut the wires at the connectors and just wire them straight together with butt connectors. go to crank it and i have no spark.expletive. so little did i know i had another b series dizzy at my house only an hour away with the right connectors on it! expletive expletive! i got the wiring harness clips from a junk yard out of an accord or somthing with like 4 inches or wire. this SHOULD fix the problem... right?
Old Oct 17, 2007 | 08:17 AM
blanco617's Avatar
Default Re: car has no spark! (j-specB20sol)
i did the same thing last night i put an obd2 dist. in my 95 civic obd1 my problem was backwards then yours thought i had no spark with the obd1 dist. and the obd2 one with the modified wiring worked perfect...
Old Oct 17, 2007 | 08:22 AM
Default Re: car has no spark! (blanco617)
ok i feel better knowing im not the only one thats done this!
Old Oct 17, 2007 | 09:34 AM
blanco617's Avatar
i think people do it alot when i was calling around looking for an obd1 distibutor they told me too just re wire/re pin the obd2 distributor and it would work.
1native
Jun 23, 2015 12:16 PM
Ct93CB7
Jan 9, 2011 05:29 PM
egreenmachine
Feb 24, 2009 11:05 AM
misternguyen
Nov 16, 2006 12:39 PM
vicsir
Oct 27, 2006 03:43 PM
