ac lines from firewall
Old Oct 17, 2007 | 08:12 AM
redsi89's Avatar
Default ac lines from firewall
i decided i didnt want/need ac and yanked all the lines and harware from the engine. I was wondering do i need to cap or remove the lines that come out of the firewall or are they good just chillin.
Old Oct 17, 2007 | 08:13 AM
90SICRX's Avatar
Default Re: ac lines from firewall (redsi89)
thats really up to you, at the least i would cap them off. Dependes on how you want your engine bay to look. Plus at that point it's just dead weight
Old Oct 17, 2007 | 08:25 AM
UfoTofU's Avatar
Why not just remove them?
I just took the AC system out of my 91 CRX and actually removed the whole assembly that is behind the glove box. I beleive it is called the evaporator.
You can see it here all removed:
If you are into it I would just gut it out and seal up the hole in the box where the lines go through the firewall and seal up the hole in the firewall as well.
Shot behind the glovebox :
It is easy enough to get out and would get rid of the lines poking into your engine bay as well as shed a little bit more weight.
This is all the stuff I removed when I tore mine out. I'd say somewhere around 40 pounds of components.
Old Oct 17, 2007 | 08:44 AM
gursh d's Avatar
Default Re: ac lines from firewall (UfoTofU)
I would just finish what you started and take out the lines. The 2 AC lines are actually a part of the AC evaporator (I think that's what it's called) that is enclosed in a black box.Behind your glove compartment underneath your dash, you'll see a black box held into place by 2 bolts.Once the black box comes out, you can disassemble the box, and remove the AC evaporator. Reassemble the box, and bolt it back up. To keep the moisture out, I used duct tape to cover the holes on the black box where the AC lines once were.
Old Oct 17, 2007 | 08:45 AM
90crxdriver's Avatar
https://honda-tech.com/zerothread?id=1839838
here's how I did it. I removed it all. now the heat/defroster blows a lot harder.
Old Oct 17, 2007 | 09:04 AM
redsi89's Avatar
Default Re: ac lines from firewall (90crxdriver)
nice thanks a lot. huge help! high five
Old Oct 17, 2007 | 09:08 AM
UfoTofU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crxdriver &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1839838
here's how I did it. I removed it all. now the heat/defroster blows a lot harder.</TD></TR></TABLE>
Nice write-up!
Old Oct 17, 2007 | 09:44 AM
90SICRX's Avatar
do you have to put the black box back in? Is it apart of the blower/defroster system?
Old Oct 17, 2007 | 12:13 PM
Default Re: (90SICRX)
yes you have to put it back in or the fan won't blow air threw the heating system. if you look hard there is a non ac air duct that replaces it. but its cheaper to just sill the black box.
nomoreavril
Apr 7, 2009 11:10 AM
NoVALude
Apr 10, 2006 09:26 AM
Saosinx
Jan 31, 2006 02:12 PM
gsr98vtec
Jul 13, 2002 12:18 PM
gsr98vtec
Jul 11, 2002 09:16 PM
