making my car lighter
Old Oct 17, 2007 | 08:00 AM
stock99si's Avatar
Default making my car lighter
okay im just curious, ive stripped a lot of cars for drag and ****, but i just wanan know what u think about 50 lbs would have effect on the speed? would it be a noticeable dif if 2 exact cars were goin at it but one was 50 lbs less... just curious
and also do smaller wheels make a big dif? comparing for ex the 15 inch with a 17 inch wheel.
Old Oct 17, 2007 | 08:28 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: making my car lighter (stock99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">okay im just curious, ive stripped a lot of cars for drag and ****, but i just wanan know what u think about 50 lbs would have effect on the speed? would it be a noticeable dif if 2 exact cars were goin at it but one was 50 lbs less... just curious
and also do smaller wheels make a big dif? comparing for ex the 15 inch with a 17 inch wheel.</TD></TR></TABLE>
they say that 100lb = 1/10 of a second. So your 50lb weight reduction is the equivalent of you shaving your legs before you go running. Useful for a race car where EVERY little bit counts. But not a big deal for a street car. Try taking a dump before you race. Not only for weight reduction...but for comfort.
Smaller wheels usually mean less weight. Less rotating mass will make your car noticeably faster. Smaller OVERALL diameter of wheels/tires has the same effect as lowering the gearing. Faster acceleration, slower top speed. 17s look stupid on civics anyway.
Old Oct 17, 2007 | 08:40 AM
LIMITLESS22's Avatar
Default Re: making my car lighter (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
Old Oct 17, 2007 | 09:29 AM
THEDirtyDseriesWOOT's Avatar
yep samlle wheels mean faster acceleration.. thats why most slicks come in 13 and 15 inch rim.. and cause 17's would look retarded lol
my car with my buddyclub 15s vs 16 inch rotas is a huge diff on a stock motor
Old Oct 17, 2007 | 10:40 AM
AWD Terror's Avatar
Default Re: (THEDirtyDseriesWOOT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">yep samlle wheels mean faster acceleration.. </TD></TR></TABLE>
Not always. In theory yes, but the weight plays a huge factor in this.
Old Oct 17, 2007 | 10:44 AM
instrument's Avatar
wheel weight makes a huge difference on braking.
Old Oct 17, 2007 | 12:34 PM
gsr x civic's Avatar
why dont you just lose weight?
anorexia doesn't sound that bad, does it?
Old Oct 17, 2007 | 12:46 PM
JKov240's Avatar
Default Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just lose weight?
anorexia doesn't sound that bad, does it?</TD></TR></TABLE>
lmao...good stuff
Old Oct 17, 2007 | 04:03 PM
Default Re: (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">
lmao...good stuff </TD></TR></TABLE>
;o
Old Oct 17, 2007 | 07:24 PM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">yep samlle wheels mean faster acceleration.. thats why most slicks come in 13 and 15 inch rim.. and cause 17's would look retarded lol
my car with my buddyclub 15s vs 16 inch rotas is a huge diff on a stock motor</TD></TR></TABLE>
well...slicks come in small diameter wheels because you want a bigger sidewall. You want the sidewall to crinkle instead of make the tread break away.
Old Oct 17, 2007 | 08:42 PM
teggrl's Avatar
Default Re: (B serious)
I have 17s what wrong with that, with big rotors under them cant use any smaller rims. good info in here though up
Old Oct 17, 2007 | 09:51 PM
Hardedge's Avatar
Have you ever noticed that the car is noticabley slower when you have one or more passengers. If you can shed the equivalent weight of the preferable passenger, the hot chick (110 to 120 lbs), or your Cheet-O eat'n best friend (220 lbs), then you'll notice a difference. Plus, when that person is back in the car, it'll be just as fast as it originally was. Also, you'll probably feel a bigger difference in handling than in accelleration. The car would be faster if you turn the A/C off than if you shed 50 lbs.
As far as the wheels go, it comes down to the concept of rotational inertia. The theory is that a wheel (in this instance) requires more and more power to rotate as the center of mass gets further from the center of the wheel (i.e. a larger diameter wheel). However, you'll then ask yourself, what if the larger wheel has significantly less mass than the smaller wheel? Right, then it should balance out. It's a matter of the mass to size ratio. But then again, if you find an aftermarket 17" wheel with less mass than the stock 15" then you can find an aftermarket 15" wheel with far less mass than the stock wheel. Larger wheels are simply for looks or for clearing large brake systems. And by the way, rotational inertia obviously applies to brakes and everything else for that matter.
Old Oct 17, 2007 | 09:55 PM
fmrprojects's Avatar
Default Re: (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
Not always. In theory yes, but the weight plays a huge factor in this.</TD></TR></TABLE>
then why does all the top fuel dragsters have small light wheels in the font and imports have lighter wheels for trailing wheels.
smaller wheels does make the car go a little faster. less rotating mass. but then again with a smaller wheel you cant have it that wide. only good for going straight
Old Oct 17, 2007 | 10:14 PM
marshun's Avatar
Default Re: (fmrprojects)
if you've stripped a bunch of cars for dragging...why this question?
Old Oct 17, 2007 | 11:46 PM
B serious's Avatar
Default Re: (marshun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun &raquo;</TD></TR><TR><TD CLASS="quote">if you've stripped a bunch of cars for dragging...why this question?</TD></TR></TABLE>
damn...lol good point.
Old Oct 18, 2007 | 04:18 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">
smaller wheels does make the car go a little faster. less rotating mass. but then again with a smaller wheel you cant have it that wide. only good for going straight</TD></TR></TABLE>
Ok, go home and put some lawn mower tires on your car and see how it works out.
Old Oct 18, 2007 | 05:21 AM
crazyguy's Avatar
weight reduction on driver too
Old Oct 18, 2007 | 09:10 AM
taking wieght out helps... end of discusion we could go on forever about the details and theorys btu a 1600lb car with 200whp is gonna destroy a 2300 lb car with 200whp
Old Oct 18, 2007 | 09:43 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEDirtyDseriesWOOT &raquo;</TD></TR><TR><TD CLASS="quote">a 1600lb car with 200whp is gonna destroy a 2300 lb car with 200whp</TD></TR></TABLE>
If only things were this easy.
There are way more things to factor in that just weight. How bout automatic/manual, gear ratios, traction, power band, and driver error just to name a few.
Old Oct 18, 2007 | 10:45 AM
97Ej6mike's Avatar
Light is fast, no fat chicks allowed. Simple as that.
Old Oct 18, 2007 | 10:16 PM
stock99si's Avatar
its a question because im curious to see if someone could tell me anyting from past expiriences for ex, racing someone with same car but other car was lighter and seeing how much the lighter car won by.
Old Oct 19, 2007 | 12:09 AM
B serious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">its a question because im curious to see if someone could tell me anyting from past expiriences for ex, racing someone with same car but other car was lighter and seeing how much the lighter car won by.
Well, me and my friend have the same S2000. Same color....same mods....everything. It's really homosexual.
Even if I have a small person in my car, it makes a difference. 50lbs, however...is negligible.
I'd rather have my AC and my interior than go .1 seconds faster or something.
Old Oct 19, 2007 | 12:26 AM
Eran's Avatar
HT White Ops
Remove your hood, fenders, bumpers, bumper covers, seats, doors, moonroof, trunk, gas door ...
Hell, remove your wheels too, those weigh a ton.
Old Oct 19, 2007 | 02:04 AM
eg6joey's Avatar
true if u want to go lighter then cut all the brackets take ur bumper support out
Old Oct 19, 2007 | 12:00 PM
stock99si's Avatar
okay lets say a 100 lbs, how much would he take u by?
scorched0
Feb 2, 2006 06:35 PM
civicguy1984
Nov 19, 2004 08:02 AM
DonKey or Horse
Aug 10, 2004 10:38 AM
Another Drew
20
Oct 2, 2003 09:00 AM
HondaNewbie
Feb 1, 2002 08:09 PM
