I have a f22b1 engine and wont to swap to h22a.
Old Oct 17, 2007 | 06:34 AM
lshnjhsn's Avatar
Default I have a f22b1 engine and wont to swap to h22a.
only question I have is a will a Turbo-Charger off a f22b1 engine that i have and i wont to swap to h22 engine will that turbo work
Old Oct 17, 2007 | 06:53 AM
captain obvious's Avatar
Default Re: I have a f22b1 engine and wont to swap to h22a. (lshnjhsn)
H22 = fiber reinforced cylinder sleeves = no aftermarket pistons without resleeving = low boost limitation
Old Oct 17, 2007 | 08:45 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: I have a f22b1 engine and wont to swap to h22a. (captain obvious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captain obvious &raquo;</TD></TR><TR><TD CLASS="quote">H22 = fiber reinforced cylinder sleeves = no aftermarket pistons without resleeving = low boost limitation</TD></TR></TABLE>
thanks for that but that didn't answer his question did it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshnjhsn &raquo;</TD></TR><TR><TD CLASS="quote">only question I have is a will a Turbo-Charger off a f22b1 engine that i have and i wont to swap to h22 engine will that turbo work </TD></TR></TABLE>
you should be able to re-use the turbo but you'll need a new manifold.
Old Oct 17, 2007 | 08:52 AM
Default Re: I have a f22b1 engine and wont to swap to h22a. (TouringAccord)
I know it didn't help, but he would prolly get most bang for the buck with the F series. He probably isn't wanting to spend all that money on somethin that's gonna blow up.
teamitr
Apr 28, 2008 09:43 PM
BlueLude 94
Apr 17, 2006 10:23 PM
mostasteless
May 31, 2005 02:59 PM
Jason kiDD
Mar 28, 2005 05:23 AM
killablaze
Nov 24, 2004 02:53 PM
