i think i may have an ls crank in my gsr?
Old Oct 17, 2007 | 05:45 AM
patrick4588's Avatar
Default i think i may have an ls crank in my gsr?
ok, i bought this block and crank together. i was told it was a gsr crank, but after getting the motor put together, im not sure. on rotation of the crank, the pistons go just barely above the top of the cylinder. and i mean barely. but still past it. but what really has me thinkin its an ls is because the gsr rods i have a little side to side play on the crank. the ls crank has wider journals than the gsr right?
Old Oct 17, 2007 | 09:07 AM
ttt
Old Oct 17, 2007 | 11:09 AM
onepoint6i's Avatar
Default Re: (patrick4588)
gsr are wider than ls..
is the block disassembled?
Old Oct 17, 2007 | 11:19 AM
yes. its an aebs block with cp pistons and eagle rods. i just assembled it and the rods have a little side to side play. just worries me. the crank has been micro polished and balanced. i was told it was a gsr
Old Oct 17, 2007 | 02:34 PM
all-mtr-teg's Avatar
If you had an LS Crank w/ GSR rods in a GSR block the pistons would definately come out the block, but even with the LS rods, depending on what pistons you use cause of the piston height variations, and if the block has been decked enough, the pistons will come out the block, mines did.
Old Oct 17, 2007 | 03:05 PM
yeah its been decked and i am pretty sure thats why it comes out a little. is there suppose to be a little side to side play with the eagle rods?
Old Oct 17, 2007 | 06:57 PM
Im not sure what the rod to crank specs are for stock, but i doubt eagle rods will be more than stock clearance. Check a manual and then measure your play.
Old Oct 17, 2007 | 07:07 PM
the bearing clearance is within spec, but it has side to side play
Old Oct 17, 2007 | 08:36 PM
4g hatch's Avatar
your allowed some rod end play. look it up in a shop manual for exact specs but im thinking the max is around .0016. also if its a ls/b20 crank only one counter weight will be machined. the gsr/type r have both machined,and the type r have a r stamped on them
Old Oct 18, 2007 | 12:33 PM
ill try to measure it with some feeler gauges when i get home. hopefully itd within spec. so the gsr journals are wider?
Project_EK
Jun 5, 2008 09:17 PM
egturbolsvtec
Mar 6, 2006 06:14 PM
electric_rex
Dec 5, 2004 02:57 PM
