Where should i go from here?
Well guys, yesterday was a bad day ... RIP my baby, my gsr is blown
. Pulled the head off today, one valve broke, put a whole in a piston, and cracked the sleeves, so pretty much the whole long block. So where should i go from here. How much does it cost to get new sleeves, and installed? how much for some pistons, and install? For now i might put together a mini me. I bought me a z6 head for 70 about 2 months back, and have a b7 in the backyard. so im just gonna do a mini me until i come up with something else. I already miss her
... i pulled the b7 head off and noticed that the sleeves on this block were hella dirty, how can i clean this up? Thanks guys
clean it with some parts cleaner or you could take it to a machine shop and let them put it in a bath with whatever they use. and I would just do an ls/vtec or something since the block is shot. its the perfect time.
well the head and block are gone, but im left with a jdm gsr lsd tranny ... i was even thinkin h2b! here are some pics ...
RIP
RIP
if you look at the bottom of the pics you can see the crack on the sleeves, im still mad, i never pushed the engine to the limits, and it did this to me
I guess it depends on your goals. If you just want a bolt-on type of vehicle I would just buy another long block and call it a day. If you are looking for a high boost application or a strong all motor car then I would say re-sleeve it and build the current block. Speaking from experience building a motor gets real expensive real fast so be prepared. Oh and to answer your question about sleeving prices it seems to run about $1000 from what I've seen. Good luck
Sorry about the motor..that sucks, but you definately good make the best out of this. H2B would certainly be a cool choice
or your could get a B18b or even a B20 for that matter and put them up to some boost if that's what you want.
How much money you got to spend?
or your could get a B18b or even a B20 for that matter and put them up to some boost if that's what you want.How much money you got to spend?
92EG8
12
Apr 30, 2008 04:30 PM
