Suspension & Brakes Theory, alignment, spring rates....
choosing brakes
Old Oct 16, 2007 | 08:10 PM
ware's Avatar
Default choosing brakes
Not sure if this is the right place to post this question, if it isn't can mods please move. Ok so im in need of new pads/rotors. I have a Daily Driven 2000 honda civic ex with stock motor. Im going to use steel braided brake lines, Hawk pads, and as far as rotors.. i cant decide between Brembo Blanks or Slotted (not drilled). I want to know ups and downs between these two. Discuss
Old Oct 16, 2007 | 08:18 PM
Stoich EG2's Avatar
Default Re: choosing brakes (ware)
brembo blanks. no need to get slotted. what are you doing with your car? just DD?
i dont think slotted rotors can be turned(resurface) if they were to warp
Old Oct 17, 2007 | 03:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
AutoZone rotors and pads are perfectly fine for daily driving
<-- been using those for 150K+ miles w/o issue, even have a few autocrosses on them.
Old Oct 17, 2007 | 06:42 AM
gsrob's Avatar
Default Re: choosing brakes (Stoich EG2)
I just ran my new slotted rotors on a brake lathe and it worked just fine. They were brand new but it's always a good idea to make sure they are true before just slapping them on, especially the fronts.
Old Oct 17, 2007 | 02:22 PM
ware's Avatar
Default Re: choosing brakes (gsrob)
it will be daily driving.. i drive it hard on the streets though. I want to know if slotted really makes a difference between the blanks
Old Oct 17, 2007 | 03:10 PM
slammed_93_hatch's Avatar
i use the cheapest rotors i can find. Most of the time i end up spending 25 dollars for a set of front rotors.
This is on a RACE CAR. No need to spend $$ for rotors on a street car.
Old Oct 17, 2007 | 03:35 PM
ThoseDarnKids's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote"> i drive it hard on the streets though.</TD></TR></TABLE>
Well, you shouldn't, but I'll make the point that your driving "hard on the streets" is probably less abuse than a typical out/in lap on the track. If a tracked Civic with more power and grip doesn't need slotted rotors, a street driven Civic doesn't either.
I don't know about those Autozone rotors, though. I bought a pair, once, and the stud holes were slightly of center, so they'd kinda wobble up and down. I took 'em back. Whatever you get, blanks are fine.
Old Oct 17, 2007 | 08:01 PM
ejprimo's Avatar
Default Re: choosing brakes (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i use the cheapest rotors i can find. Most of the time i end up spending 25 dollars for a set of front rotors.</TD></TR></TABLE>
i like to use the cheapest rotors from kragen and change them everytime i change pads.
Old Oct 18, 2007 | 06:10 AM
ware's Avatar
Default Re: choosing brakes (ThoseDarnKids)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThoseDarnKids &raquo;</TD></TR><TR><TD CLASS="quote">Well, you shouldn't</TD></TR></TABLE>
not racing hard, im just always ready to get were im going.. at times we go out to an airfield about an hour away to run..
Old Oct 18, 2007 | 02:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">it will be daily driving.. i drive it hard on the streets though. I want to know if slotted really makes a difference between the blanks</TD></TR></TABLE>
The only "difference" slotted rotors will "make" over blanks is in the balance of your bank account.
Old Oct 19, 2007 | 11:51 AM
MeIpk3's Avatar
Blanks wil be fine for DD.
dragonkx
13
Jun 29, 2010 07:37 AM
sony224422
Aug 13, 2006 04:30 PM
Tad
Jun 22, 2005 12:30 PM
abcriderdafa
Nov 29, 2004 04:54 PM
Vampyre
Nov 1, 2002 09:46 PM
