ground control???
Old Oct 16, 2007 | 06:57 PM
KOKEY04's Avatar
Default ground control on stock 2000 civic si shocks??? pls help...
just wondering if you guys can help me out, i was wondering if ground control works good with my stock shocks??? i have 2000 civic si...pls reply
Modified by KOKEY04 at 9:33 PM 10/16/2007
Old Oct 16, 2007 | 06:59 PM
97Ej6mike's Avatar
Depends how far of a drop your planning. If your struts arent shot as it is, you shouldnt have any issues with lowering it up to about an inch, generally like eibach lowering springs would do. Anything lower than that, you should consider aftermarket struts. Just my $0.02
Old Oct 16, 2007 | 08:09 PM
KOKEY04's Avatar
Default Re: (97Ej6mike)
i was planning to lower it 2"...is that still ok???
Old Oct 16, 2007 | 08:34 PM
dad0c402's Avatar
Default Re: (KOKEY04)
i'm with 97j6mike, minor dropping is okay with your stock shocks, but if it was me any kind of a drop i would just do a whole aftermarket spring and damper set-up. 2" is more then minor, so can you do it yes, but after awhile your shocks will go bad and need replacing anyway.
Old Oct 16, 2007 | 08:47 PM
KOKEY04's Avatar
Default Re: (dad0c402)
thanks guys, i really appreciate your comments...
miss.Soshinoya
Suspension & Brakes
May 27, 2010 06:24 PM
all-mtr-teg
Suspension & Brakes
Mar 5, 2007 02:42 PM
koulaid
Suspension & Brakes
Nov 18, 2006 06:10 AM
MadWackOops
Nov 9, 2003 09:28 PM
