91 Integra on GC wont go low!!!!
I just installed my new suspension. I have off the shelf ground controls with tokico illuminas. The back can tuck tire but the front goes about one finger gap. Is there any way that i can lower the front more. I want to eliminate the gap in the front. Any help will be well appreciated. Also the instructions told me to cut the stock dust covers in the back. It diddnt say anything about the front ones. Am i supposed to cut the front ones too?
Thanks
Thanks
i believe so, i had to take mine off. i have GC/koni though. they're probably sitting on your GC sleeve which is preventing the car from dropping. oh and i have like 1/2 finger gap in front, the GC's are like 8 turns from the bottom of the sleeve. this is on a DA also. sometimes my UCA's hit the strut tower but that's it.
yeah i think they are sitting on the little rubber sleeve that goes underneath the metal sleeve. But would that cause the car not to go any lower? Mine are turned all the way down and still a finger gap.
ya you should be able to lower it more.
this is on Koni/GC still has 1-2" to go on the front and 2-3" to lower on the back.
I took the stock dust covers off the front. It rides alot better and it solved to problem. Will it void tokicos warranty if you take them off?
