Suspension & Brakes Theory, alignment, spring rates....
Which bushings wear the most?
Old Oct 16, 2007 | 05:32 PM
vinuneuro's Avatar
Default Which bushings wear the most?
Which bushings typically wear the most in Honda double-wishbone suspensions..which make the largest difference when replaced in an older car?
Modified by vinuneuro at 11:23 PM 10/16/2007
Old Oct 17, 2007 | 03:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Probably any of the load-bearing lower control arm bushings, as well as the big trailing arm bushings.
Don't use polyurethane, though, unless you want to change them out all over again in just a couple of years. Stick with OEM rubber or OE replacements.
Old Oct 17, 2007 | 10:53 AM
Tyson's Avatar
Default Re: (PatrickGSR94)
im going to agree with patrick. the LCA bushings get the worst of it.
also, the rear upper arm, especially the inner dogbone bushing gets a lot of abuse because of its configuration and the angle of the short control arm.
but really, any and all bushings can go bad.
im guessing you drive a prelude? i dunno anytihng about preludes, but there might even be prelude specific bushings that need more attention too.
just gotta check each out.
JZiggy
Honda CR-V & Element
Dec 14, 2017 10:24 AM
92LudeSR
Jan 6, 2006 02:30 PM
yOnKiNaToR
Jan 9, 2005 03:28 PM
SoulSurfer
Dec 10, 2002 10:45 AM
