quick axle question for b16 swap!! please help
ok i have a BAD shake under load in my 91 hatch with a b16 swap. im running the 1"longer intermediate shaft, so im using 86-89 integra axle on the drivers side and 90-93 one on the passenger side.
my question is this. are the 90-93 axles for the passenger side longer than the 86-89 ones? because i know the drivers side is shorter on the 86-89 one. im wondering if the same goes for the passenger side.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 »</TD></TR><TR><TD CLASS="quote">than use a 90-91
i dont think they are the same length
well i know at the parts store i said 92 integra. are the 92-93 different than the 90-91?
92-93 Integra axles shouldn't be different, I think the only different axle you can get for the DA are the ones with OR without ABS.
i was running the axels out of my old 92 teg and 92 teg inter shaft. and it fit perfectly. i didnt even take off the dust cover either. and my da had abs too. perfect fit. no shaking! the only problem i had is the pass side boot came off but i dont think that had anything to do with them being in an ef.
RACING INTEGRATION
Mar 3, 2006 08:09 PM
crexer
27
Dec 22, 2004 10:39 PM
