GC adjustable sway bar..
Any one have any experience with it, or comments to other ones.
Honda Civic and Integra Adjustable Sway Bars
Available in two sizes. 22mm for street use and 25mm for race use. Steel reinforcements bolt to the chassis in 5 places, and Delrin bushings can not squeek like urethane bushings. $239 each.
I think this is for the non ITR cars.. the rear subframe is different so those reinforcement pieces wont fit on an R.. however you could still get it to fit I'd think.. as long as the two bolt holes are at the same spot/distance front another.. they should be since it uses one stock bracket location and one abs bolt hole I believe.
I'm open to suggestions on different brands for the ITR
discontinued to my knowledge..
http://www.randdmotorsports.com/ has a good price on the JDM bar but my buddy Todd00 was quick to point out the 1MM difference wasn't that noticable.
Anyone have any thoughts about other aftermarket options. There always higher spring rates for the rear... which are on order. Upper tie bar helps too. Thoughts?
higher spring rates and you may have to also upgrade the shocks to handle the spring rate.
Just say this because I run 400 GC in the rear and from post a while back that Konis may need to be revalved past 400 to be able to make any adjustments or for the adjustment to the shock to make a difference.
And if the car is a daily driver it makes the the ride on the streets horrible considering most street are not in very good shape.
I figured an adjustable sway bar could be adjusted easily between the street and track, or maybe not?
mugenNR10
Suspension & Brakes
Sep 6, 2016 09:59 AM
96 GSR-T
Suspension & Brakes
Mar 11, 2008 07:21 PM
Jaesung
19
Aug 13, 2004 11:45 AM
