clutch?
Old Oct 16, 2007 | 03:38 PM
slow88crx's Avatar
Default clutch?
So I just replaced my clutch about 5k miles ago. It already feels like that it is slipping. I'm not entirely sure. It seems as though each time that I get into the car and go some where I got to push the pedal further and further back. The pedal is getting stuck sometimes when I shift. SO could it just be that I need to tight my clutch on the bracket or is my clutch really slipping?
Old Oct 16, 2007 | 03:57 PM
Murk 'EM's Avatar
Default Re: clutch? (slow88crx)
try adding break fluid to the clutch resivore, and bleed it if its not already done
Old Oct 16, 2007 | 04:00 PM
slow88crx's Avatar
Default Re: clutch? (Murk 'EM)
aight
Old Oct 16, 2007 | 05:11 PM
kay_animation's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Murk ’EM &raquo;</TD></TR><TR><TD CLASS="quote">try adding break fluid to the clutch resivore, and bleed it if its not already done</TD></TR></TABLE>
Yes, make sure you bled it right and the levels are correct. Also when you first install a clutch there is a break in point you have to follow. When you first cut the car on and you have to keep it under a certain rpm for a certain amount of miles. Go to clutch masters website if you wanna see the details but if you don't break it in right, it's not good. Also could just not be fully broken in yet
s13hero
14
Nov 21, 2010 04:57 PM
GranddaddyPurple
Feb 10, 2008 04:33 AM
Pompiuses
May 31, 2005 01:46 PM
Buckshot
Nov 17, 2002 08:43 PM
Buckshot
Sep 11, 2002 05:05 AM
