what oil is best? 97' ls w/ 124,xxx miles
Old Oct 16, 2007 | 08:37 AM
lmike6453's Avatar
Default what oil is best? 97' ls w/ 124,xxx miles
like the title says-97' ls w/ 124,xxx miles....
i put in conventional 5w30 pennzoil but was wondering if i should use the high mileage stuff which is more expensive...what is the significant difference? thanks for helping
Old Oct 16, 2007 | 08:40 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: what oil is best? 97' ls w/ 124,xxx miles (lmike6453)
i believe there is a butt load of threads on oil already
Old Oct 16, 2007 | 08:58 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what oil is best? 97' ls w/ 124,xxx miles (danteisme)
Wow, a new topic that no one here has ever discussed before!
Old Oct 16, 2007 | 09:27 AM
DC2TEGGA-GSR's Avatar
if you've got leaks from your motor, i would suggest the high mileage, it helps recondition the seals and fill in scuffs and minor scratches on cylinder walls to increase compression, and prevent against oil burn off. conventional is just basic, if you really care about your car, you want to use something better. how would you feel if you were your car and you only were given the absoulute basic?? consider full synthetic.
Old Oct 16, 2007 | 09:28 AM
AWD Terror's Avatar
Default Re: what oil is best? 97' ls w/ 124,xxx miles (DC2TEGGA-GSR)
If you really want to protect your car, use full synthetic.
Old Oct 16, 2007 | 09:39 AM
redDAinteg's Avatar
Default Re: what oil is best? 97' ls w/ 124,xxx miles (AWD Terror)
5w30 mobil1 full syn.
Old Oct 16, 2007 | 09:43 AM
Padawan's Avatar
Darth ModerVader
I wouldn't go to synthetic at this point. Stick with a quality conventional 5W-30 either standard or high-mileage formulation (which isn't much more expensive).
Old Oct 16, 2007 | 12:35 PM
1998_4dr_gsr's Avatar
Default Re: what oil is best? 97' ls w/ 124,xxx miles (Padawan)
Been using castrol gtx 10-30w on my honda's for over 10 yrs. Current gs-r has over 187k miles. Call me cheap but it works for me
Old Oct 16, 2007 | 05:30 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">If you really want to protect your car, use full synthetic.</TD></TR></TABLE>
Synthetic is not the answer for every application. In his case, he is better off using the conventional or high mileage stuff. Synthetic is for more extreme duty and newer engines.
Does your car smoke/burn any abnormal amounts of oil? If there is no problem then just continue as you have been until things change.
Old Oct 16, 2007 | 10:02 PM
yarara0825's Avatar
Default Re: what oil is best? 97' ls w/ 124,xxx miles (Dunc)
i would prefer a mobil 1 10-30 since its a high mileage car the thikcer the oil the less it would burn
Old Oct 17, 2007 | 04:53 AM
Padawan's Avatar
Darth ModerVader
Default Re: what oil is best? 97' ls w/ 124,xxx miles (yarara0825)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yarara0825 &raquo;</TD></TR><TR><TD CLASS="quote">i would prefer a mobil 1 10-30 since its a high mileage car the thikcer the oil the less it would burn </TD></TR></TABLE>
Both a 10W-30 and a 5W-30 will be essentially the same viscosity at operating temperature. Either way, trying to prevent oil consumption by using a heavier oil is generally not a good idea.
lmike6453's Avatar
does not burn oil whatsover. thanks for the advice everyone-i looked through posts about oil for the difference between conventional and high mileage but couldn't find anything so that's why i started this thread...
so i'm guessing if i start to smell oil or see it burning change to 10w-30?
gonein60seconds
Dec 11, 2008 02:48 PM
ae86erinvegas
Sep 8, 2006 10:12 AM
r3v da t3g
Mar 3, 2005 01:05 PM
SiR Inspired ED7
May 31, 2004 04:58 PM
vabchaccord
Dec 10, 2003 08:55 AM
