Vote: Have had distributor problems or no? common vs. uncommon
check out my problem: https://honda-tech.com/zerothread/2126821
Distributors do have components that wear, and they shouldn't be considered "lifetime" items. Try replacing the cap and rotor, and see if that helps your problem. If not, you may need a whole new unit.
I had to replace the distributor on my 90 GS, then after I sold it the guy told me that it went out again a few months after he bought it.
I had to replace the coil on my 95 LS three times
And the maintenance records look like the coil was replaced on my current 93 LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmike6453 »</TD></TR><TR><TD CLASS="quote">wow that's crazy...distributor king states that it's because they can't withold high heat from the americas and were designed for japan-wonder if hes right</TD></TR></TABLE>That's stupid. If that's what they said, that's total b.s. Just google image "Earth" and look and see where Japan lines up (in relation to the equator) with North America. It's nearly identical.
From: Why To Steal My Car, NC, United States Of America
you guys do know that a whileeeeee back honda/acura had a recall on all distrubtors so thats why they break or dont work after a long time so i guess if your still covered under warranty they cover dizzys not sure but all i no honda/acura had a recall on dizzy's
as a rule of thumb, all honda owners should always keep in their glovebox:
a new main relay
a new ignitor
a new coil
a 10 mm wrench
a phillips screwdriver
and with those things, you can basically fix 75% of problems you will ever encounter
a new main relay
a new ignitor
a new coil
a 10 mm wrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">as a rule of thumb, all honda owners should always keep in their glovebox:
a new main relay
a new ignitor
a new coil
a 10 mm wrench
and with those things, you can basically fix 75% of problems you will ever encounter</TD></TR></TABLE>
i got all of that and my car still doesnt start... the only way it starts is if i jump the main relay and i got a new main relay from honda so yupp.... haha i dont know what it can be.
a new main relay
a new ignitor
a new coil
a 10 mm wrench
I had a really weird dizzy problem. The oil seal inside the dizzy spindle wore out and I was leaking oil out the bottom of the dizzy housing. I'm not talking about the o-ring on the outside of the dizzy. It's the one inside the dizzy. You can't even see it until you pull the whole dizzy apart. Unbelievable. Took forever to figure out that it was my dizzy leaking oil and not some other source. The amazing thing was the dizzy was operating just fine. LOL. So yeah, I've had dizzy problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spender1326 »</TD></TR><TR><TD CLASS="quote">I had a really weird dizzy problem. The oil seal inside the dizzy spindle wore out and I was leaking oil out the bottom of the dizzy housing. I'm not talking about the o-ring on the outside of the dizzy. It's the one inside the dizzy. You can't even see it until you pull the whole dizzy apart. Unbelievable. Took forever to figure out that it was my dizzy leaking oil and not some other source. The amazing thing was the dizzy was operating just fine. LOL. So yeah, I've had dizzy problems. </TD></TR></TABLE>
that will eventually drown the electronics inside and ruin the internals. you need a new housing. when this happened to me, i just picked up a used unit then swap all your insides into it.
