suspension questionaire! m factory parts, top of the line build
Old Oct 15, 2007 | 10:09 PM
TheSauceSpot's Avatar
Default suspension questionaire! m factory parts, top of the line build
i tried to search suspension, and car specific not much info on this yet.
Is anyone using M Factory suspension products on there EF chassis?
http://www.teammfactory.com/pr...20Kit
there sway bar kit looks very good, any reviews?
only the color kills me!
anyone using the toe kit or camber kit?
the rear LCA's look amazing, just curious about their other products.. any advice is helpful..
cant decide on a what to go with... i want a top of the line suspension, nothing short of perfection.. let me know what parts to go with..
ASR doesnt make a subframe brace
what else can be changed..energy suspension bushings?
Old Oct 15, 2007 | 10:22 PM
1989CivicSi's Avatar
Default Re: suspension questionaire! m factory parts, top of the line build (HOTSAUCE01)
^ Planning on going mFactory myself once I get a few more things squared away on my car, but from everything I've heard their products are great/customer service is top notch. You might want to call mFactory about that rear subframe brace though. Not sure if it's included in the EF kit as it isn't really necessary (swaybars on our cars mount to the OEM towhook location, not the subframe). I've seen pictures of the ASR brace and it's mounted to the OEM towhook location as well .
Old Oct 15, 2007 | 11:53 PM
yuve seen an ASR subframe brace on an ef?
Old Oct 16, 2007 | 04:39 AM
Autoworks's Avatar
Default Re: (HOTSAUCE01)
That is a really nice looking sway bar setup. I've never seen it (up until now)
Putting together the perfect suspension will depend alot on what the intended use will be. With that said, the M Factory piece looks like a nice starting point. ( I personally use a ST sway bar, K Sport LCAs, NRG rear lower tie bar, stock front sway bar, KYBs, and Ground Controls)
Old Oct 16, 2007 | 04:43 AM
CRX Toad's Avatar
ASR doesn't have a subframe brace for 88-91. I think you are thinking of the ASR sway bar.
Old Oct 16, 2007 | 10:15 PM
hopefully ASR steps up and comes out with something soon...
untill then its looking like
- KY/GC coils
-ST Sway Bar
-MFactory LCA'S, Toe Kit, Rear camber kit, tie bar.
-PWJDM spherical bearing
- what do you think about fron camber kits...
http://cgi.ebay.com/ebaymotors...ZWDVW
is it still worth it to buy a Energry Suspension Full kit??
Modified by HOTSAUCE01 at 3:17 PM 10/24/2007
Old Oct 24, 2007 | 02:20 PM
Any help on these last pieces... REVO stage 2!! anyone using these?
is it worthusing the ES kit?
Old Oct 24, 2007 | 02:24 PM
prettylew's Avatar
took this from the JDMuniverse boards but just so u know heres an ASR brace on an EF. drooling is ok
Old Oct 24, 2007 | 03:16 PM
Default Re: (prettylew)
WOW!! at least i know it can be done... now HOW?!????
Old Oct 24, 2007 | 03:45 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOTSAUCE01 &raquo;</TD></TR><TR><TD CLASS="quote">WOW!! at least i know it can be done... now HOW?!????</TD></TR></TABLE> Better yet, why?
They REALLY arn't needed on these cars.
MF factory makes top notch parts, the LCAs in my eyes are a waste of money, I and many others who've been road racing for years feel they arn't needed.
Old Oct 24, 2007 | 04:23 PM
jchrm80's Avatar
i have the m factory rear toe and camber adjusters for my crx w/ DA rear disk conversion high quality and easy to install.
Old Oct 24, 2007 | 08:04 PM
gospeedgo1's Avatar
Default Re: (jchrm80)
didnt ASR come out with a sway bar for EFs? i thought i saw a prototype of it in the suspension/RR forum a while back. doesn't mount to stock area.
Old Oct 24, 2007 | 11:00 PM
Default Re: (gospeedgo1)
still cant decide on skunk2 LCA's or M-Factory?
cant seem to find a good front upper control arm either... hows this rhino company?
Old Oct 24, 2007 | 11:47 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote">
x2.
Old Oct 25, 2007 | 04:53 AM
IT GUY's Avatar
Default Re: (goforbroke)
I used all of MFactory's rear suspension stuff. Haven't driven on it yet, but the parts are well made. Probably the beefiest toe adjusters and camber arms I've seen.
Old Oct 25, 2007 | 06:09 AM
Default Re: (IT GUY)
So if the M-Factory is "AMAZING" dont you think its worth the money?
Any reviews on either of these Camber Adjustable UCA's?
RHINO: http://cgi.ebay.com/ebaymotors...ZWDVW
REVO STAGE 2: http://cgi.ebay.com/ebaymotors...ZWDVW
Money isnt an issue when you want everything done right
Old Oct 25, 2007 | 07:04 AM
MFactory's Avatar
It really just depends on your application. If you really are picky about weight savings, having LCA's that weigh only 2.5lb's each can be a godsend.
Same again can be said about the bushings. If you want the utmost precision and near-zero deflection, you can't get any better than spherical bearings.
However, some classes don't allow this sort of modification, and for some people, this may be OTT for what they require (e.g weekend warrior etc). In this case, hard rubber bushes may be the better choice. If this is the case though, you really can't get any better than the oem rubber bushes, which is why to some, keeping the oem LCA's is the best choice.
Cheap PU bushes aren't even worthy of a mention here, so I won't even go into that.
Old Oct 25, 2007 | 07:11 AM
Default Re: (MFactory)
Well... even tho i plan on hitting up road course, auto-x... im still gonna be a weekend warrior!! On ramps FTW!
M-Factory...youve been PM's
^^^these new smileys are a distraction!
RedlineMotive
131
Jan 23, 2010 07:51 AM
spaceman00
10
Apr 23, 2007 02:23 PM
