need help with burning smell while driving..
Old Oct 15, 2007 | 06:23 PM
kycivicboy's Avatar
Default need help with burning smell while driving..
My friend has a 2000 Civic EX. after driving it for a little bit and the motor warmign up it starts to smell like something is burning. Kind of smells like when you first turn ona heater for the first time or liek burnign coolant. I know this sounds weird but you can smell it the strongest when making a right hand turn. Does anyone have any ideas on what this might be or soemthign we can check? thanks
Old Oct 15, 2007 | 06:25 PM
stock_honda_coupe's Avatar
Default Re: need help with burning smell while driving.. (kycivicboy)
Any leaks in the engine compartment?
Old Oct 15, 2007 | 07:16 PM
kycivicboy's Avatar
not that i can see from looking at the top. i have not crawled under it to look but when sitting still and idiling i see nothing leaking fromt her bottom either
Old Oct 15, 2007 | 07:17 PM
b16a3delsol's Avatar
Default Re: (kycivicboy)
It could be a pressure leak that just happens at certain times. so check it periodically.
Old Oct 15, 2007 | 07:27 PM
Dasfinc's Avatar
Coolant has a very sweet and distinct smell, Also pinhole Coolant leaks can give random small leaks only when warm *I had a taurus that would only leak while running.*
Old Oct 15, 2007 | 08:42 PM
HATCHBACK GORILLA!'s Avatar
might want to check the wiring....hopefully there isnt a short somewhere....id look over all the wires if it were me
Old Oct 16, 2007 | 04:59 PM
Default Re: need help with burning smell while driving.. (HATCHBACK GORILLA!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHBACK GORILLA! &raquo;</TD></TR><TR><TD CLASS="quote">might want to check the wiring....hopefully there isnt a short somewhere....id look over all the wires if it were me</TD></TR></TABLE>
Wires only smoke once. Sounds like this happens all the time. So unless you're burning more wires everytime you drive for a long time, thats not its. Plus, burnt wireing leads to other problems.
Old Oct 16, 2007 | 05:42 PM
Redbone's Avatar
Check the heater hoses too because they are back behind the motor and hard to see if they are leaking. I had this problem on my swap, heater hose was leaking and spraying over the back of the engine. Then the upper hose blew and also had to replace the hoses going into the TB/IACV. Coolant goes a lot of places in there so check them all for fluid.
Teamdiesel
40
Dec 3, 2019 04:10 PM
wanabebuff
14
Jun 1, 2017 03:25 PM
em1effekt
22
Nov 29, 2011 04:23 PM
bopbop93030
Jan 31, 2008 12:05 AM
mathews
Oct 4, 2005 02:45 PM
